Well, it took us long enough, but it looks like I have a solution that works.
The LED festoons that I used to replace the stock license plate festoons can be found at tunerdomes.com here: http://www.tunerdomes.com/index.php?...d&productId=49 These are 1 watt and draw enough current to work with no "bulb out" error. I have not tried it yet, but I assume the same bulbs will work for the other 36mm festoons in the car. The first pic is a comparison between the 1 watt LED festoon and the stock bulb, the second pic just confirms the model of festoon bulb I used. Good luck and enjoy. A word of caution for the newer members who want to try this, please read the ENTIRE original post carefully and thoroughly before attempting. If you do it wrong, you will either break the bulb holder (trying to pry it off) or lose your wires inside your trunk lid.
Phantom Black S5, Black Silk Nappa, SS Mesh Inlay, Nav, Tech, B&O, 1" H&R Sport Springs, Hüper Optik, plus other stuff... Chicks dig me. |
could do with a list of which bulbs in the car this might replace, ie vanity mirror? footwell lighting? reading lights etc??
I purchased a complete set of xenon look interior lights for my M3, they were not LED but really changed the interior look to the car... I did the fogs and licence plate bulbs just to complete the look... It was a US supplier called Bimmian who provided very useful video tutorials on how to install each one, very useful to avoid sticking a screw driver somewhere you should not! pretty sure they dont do Audi, but maybe if any of you US members are nearby you could give them a call??Jason
June 08 S5 ¦ Phantom Black ¦ Black Silk Nappa Interior ¦ Carbon Trim ¦ DVD Nav Plus ¦ DAB Radio ¦ AMI ¦ Phone Prep High ¦ Bang & Olufsen ¦ Parking Plus ¦ Heated Memory Seats ¦ Auto Dipping Rear & Side Electrically Folding Mirrors ¦ Adaptive Xenon's ¦ Internal & External Lighting Mod's ¦ Cat Back Milltek ¦ BMC Filter ¦ and an APSvisit Bugger, modding has started
#3 |
Thanks for the info! Will try it.
Now, what bulbs do you use to change the backup lights (reverse lights)? The OEM are really yellow and again, I'd like some bright white, LED, or even blue tinted bulbs to light up when putting the car in reverse.
Audi S5 Meteor Gray Pearl Effect with Magma Red / Tech / Navi / B&O / Carbon Fiber Trim / Milltek Sport Catback Exhaust with Special (Slash-cut) Tips / H&R Sport Springs 1" Drop / H&R 15mm Spacers F&R |
#4 |
Hi guys, there are a few post on the forum that explain which bulbs are used for everything from the front fogs to dome light etc. Use the search feature and search for "bulbs". I will give you a little help on this one, but make sure you use the search becasue there is a wealth of good info you will find very useful.
http://www.a5oc.com/forums/showthrea...x.html?p=22535 and here: http://www.a5oc.com/forums/showthrea...2.html?p=23260 Enjoy...(and use the search) ![]()
#5 | |
High & low beam headlamp HID-D3S Parking light 2825LL Front turn signal H21W (64136) Rear turn signal 7506LL Tail light 7506LL Stop light 7506LL High mount stop light 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Fog/Driving light H11-55W License plate 6418 6418LL Long Life Upgrade: Up to twice the life of the standard lamp Back up light 921 921LL Long Life Upgrade: Up to twice the life of the standard lamp Front sidemarker 2825LL Glove box 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Map light 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Dome light 6418 6418LL Long Life Upgrade: Up to twice the life of the standard lamp Step/Courtesy light 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp 6418 6418LL Long Life Upgrade: Up to twice the life of the standard lamp Trunk/Cargo area 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Phantom Black S5 Black Interior- Stainless Inlay- Audi Navigation Plus- Technology Package- Bang & Olufsen Audio-GMG Quad Exhaust-20" HRE 790R with 305/25/20 Rears- Euro Code Headlights-H&R Street Coilovers |
#6 |
LOL, you know what? I popped open my plate lights after reading this, and those are the exact ones they shipped me...they must've shipped me the wrong ones! ! ! But they worked out and I didn't even notice until this post!
I've updated my DIY in my original post with the more current and corrected LED link: http://www.tunerdomes.com/index.php?...d&productId=49 Thanks ccompton for solving the mystery.
08 Audi S5 05 Lamborghini Gallardo Both discostick because if I wanted to play with paddles all day I would've gotten a canoe instead, it's cheaper. |
#7 |
ccom - thanks, man - you are wonderful! Time to get to ordering! Didn't even realize the reverse lights were yellowish too..something else to look into.
#8 |
I guess it depends on how much you're worried about those reverse lights. I mean, they're on about 0.1% of the time.
And I'll be expecting a royalty check for the thread title... =)
2008 A5 3.2 quattro // Meteor Gray // Black Interior // Premium // Tech // Nav // B&O // Side Assist |
#9 | |
Yeah, when I read the title of this thread, I immediately thought of your DRL/turn signal puzzle thread.I agree about the very minimal use of the reverse lights. I'm not going to bother with changing those. Plus, I'm quite pleased with how much light they put out when using the rear-view camera at night. |
#10 |
#11 | |
#12 | |
#13 |
good point well made
I was thinking we could use the diagram to list which bulbs would be used where in the car and list the led alternative... I did they they did LED's also... ![]()
#14 | |
#15 |
I'm not seeing an obvious similar solution for the 2825 (map lights and stem/courtesy lights). Any ideas there? Figured I'd order everything at once. Going to need two of these 6418 36mm 1 watt bulbs for the dome lights right? There's a light you see a lot (unlike the reverse, I agree).
#16 | |
I am ordering a couple more of the 1 watt bulbs for the dome light too...TX and I were just wondering the same yesterday on the map lights...I don't think the 2825 (wedge light) can come in an LED...but there are a lot of HID-like replacements available PIAA makes one: http://www.xtremewhite.com/ORD-Light...47-1-1-1-1.cfm
Phantom Black S5, Black Silk Nappa, SS Mesh Inlay, Nav, Tech, B&O, 1" H&R Sport Springs, Hüper Optik, plus other stuff... Chicks dig me. Last edited by ccompton; 26th May 2008 at 07:39 PM. |
#17 | |
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 I just don't know what the power draw is...but it shouldn't need to be that much. UPDATE: I just ordered a few of the LED 2825 bulbs...we'll see how it goes. I will let you know.
Phantom Black S5, Black Silk Nappa, SS Mesh Inlay, Nav, Tech, B&O, 1" H&R Sport Springs, Hüper Optik, plus other stuff... Chicks dig me. Last edited by ccompton; 26th May 2008 at 08:15 PM. |
#18 |
Hey CCompton,
I noticed your temp tag said Ohio, but your profile says Dallas, TX ???
Meteor Gray A5 3.2 Quattro|Light Gray Interior|Premium|Technology|B&O|Nav + Ordered: September 1, 2007 Pick-up: January 22, 2008 |
#19 |
Thanks for the link(s) ccom, but I get an error. Is this what you ordered?
In case that results in an error as well, did you order: V-LEDS HID WHITE M-SMT FLANK BULBS 194 168 158 2825? |
#20 | |
#21 | |
The bulbs are "wedge-type" and pretty small... the ones I was looking at are: 2 HID WHITE 6 LED LIGHT BULBS 194 168 158 2825 W5W for $7.99 (per pair) I will send them a note and ask "what's up?".
#22 |
They are out of stock, drats...waiting on a reply from V-LED to see if they filled the order or not.
However, there is a similar bulb on http://www.superbrightleds.com/cgi-b...gi?product=CAR search the page for "WLED-x6 LED", these _may_ be lower power, but I can't confirm that...If v-led didn't fill my order (before they went 'out-of-stock') then I will probably try these. TX has a couple of the WLED-x6 LED bulbs (from superbrightleds) that I may try to see if they work. I will let you know.
#23 |
If you want to use the LED festoons that didn't draw enough power for the license plate bulbs, I just tried one of the 'lower-power' (e.g. not 1 watt) LED festoons for the dome light and it worked with no errors, the only problem is that is really needs the 1 watt LED festoons to be bright enough.
Now, if you like "mood lighting", then you can just use the lower power festoons. I am going to order two more of the 1 watt bulbs to do the two dome lights, and the wedge bulbs for the map lights. So the only interior bulbs that need to be replaced are the two festoons in the dome, and the two wedge map lights. The funny thing is that the foot well bulbs in the front (by the pedals) and the back (under the seats) are already LED bulbs...why didn't they just make them all that way. ![]()
#24 |
#25 |
DOH! Thanks TX!!!
#26 |
I did notice that the foot well bulbs are LED already...odd. Darn just placed an order for 4 of those 1 watts, guess I needed 6! How do you open those dome covers anyway?
#27 |
#28 |
Okay, so that's two festoons for license plate and two for dome light. The 4 map lights are what we are still trying to figure out (2825 type I thought..?) via ccom's links...?
#29 |
Sorry, I misinterpreted your comment about ordering four of the 1-watts as being for just the interior lighting. I had forgotten you still need to get your license plate fixed up.
#30 |
Okay...so my prior post was correct (as was my order of only 4 1-watts), right?
