The Drivers Network
Go Back   A5_OC > Audi A5 & Audi S5 Forums > A5 General Q&A
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 27th July 2010, 03:56 PM   #1
xxkazxx
Send a message via AIM to xxkazxx
Default EPC & Check Engine & Vag-Com
OK So the last two morning I woke up and my car had an EPC light on, I would shut the car off and then back on and it would be gone. Then today, same thing, except the Check Engine light came on. I have several Vag-Com mods, including-Video in Motion, Dynamic Ride Control(all 4 options turned on for a vehicle without the option equipped from Audi), Rear Lights as DRLs, Brightness Adjustments on LEDs with Headlights, LEDs stay on with signal, and Ambient Light........I know some of the faults are from the DRC, so my question is, is there an easy way to set everything back to default settings through the Vag-Com before I got into the dealer? And if not does anyone have the original settings for the DRC before modding it?
VCDS Version: Release 10.6.0
Data version: 20100630
Tuesday,27,July,2010,19:51:04:51155
Chassis Type: 8T0
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F
6C
VIN: WAUCKAFRXAA045149 Mileage: 15330km/9525miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CALA) Labels: 06E-907-559-CAL.clb
Part No SW: 8K0 907 559 A HW: 8F0 907 559 A
Component: 3.2 SIMOS8.2 H06 0004
Revision: --------
Coding: 0114000A190F0121
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM32FSI8K0907559A A01006
ROD: EV_ECM32FSI8K0907559A.rod
VCID: 377626AA3F25
4 Faults Found:
6429 - Oxygen (Lambda) Sensor B1 S2: Malfunction in Circuit
P0136 00 [096] - Check DTC Memory
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 13702 km
Date: 2010.07.14
Time: 10:10:25
6430 - Oxygen (Lambda) Sensor B2 S2: Malfunction in Circuit
P0156 00 [096] - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 13702 km
Date: 2010.07.14
Time: 10:10:25
6138 - Oxygen (Lambda) Sensor B2 S1: Response too Slow
P0153 00 [096] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 13619 km
Date: 2010.07.04
Time: 22:35:45
6618 - Cam Adjustment Actuator B; Cylinder 6: Implausible Signal
P11B8 00 [104] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 14856 km
Date: 2010.07.25
Time: 11:08:09
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 G HW: 0B6 927 156
Component: 0B6 32 FSIUSA H05 0006
Revision: --H05---
Coding: 001012
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3A703F9E0C37
1 Fault Found:
4765 - Functionality limited due to Engine Control Module
P1719 00 [040] - Check DTC Memory
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 14856 km
Date: 2010.07.25
Time: 11:08:09
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Revision: -------- Serial number: --------------
Coding: 0F0D18
VCID: 7AF0FF9E4CB7
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 090000
VCID: 78F4E59672BB
Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001010037733
Coding: 08017025002400001000
VCID: 438E427A7BFD
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01071220090312
Coding: 46122000
VCID: 7AF0FF9E4CB7
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 13002 km
Time Indication: 0
Date: 2010.06.27
Time: 21:46:05
Freeze Frame:
Voltage: 13.00 V
Temperature: 28.0°C
Temperature: 27.0°C
Count: 11231
Count: 12268
Bin. Bits: 01000000
Bin. Bits: 10000011
Time: 39.00 s
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000530581
Coding: 26009011063CAF213C00000300003D3D4F9C52880001016100 0000
VCID: 3C7C39860603
Part No SW: 8T1 955 119 D HW: 8J1 955 119
Component: WWS 021209 H14 0070
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 02532C
Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
3 Faults Found:
03110 - Active Steering Control Module (J792)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 13702 km
Time Indication: 0
Date: 2010.07.11
Time: 08:45:00
00471 - Control Module for Elect. Regulated Dampers (J250)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 13702 km
Time Indication: 0
Date: 2010.07.11
Time: 08:45:00
03207 - Charisma Switch Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 13702 km
Time Indication: 0
Date: 2010.07.11
Time: 08:45:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940934304350
Coding: 200101
VCID: 3E78338E101F
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD05BNFE
Coding: 303338334330303030304A55304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4280477E64E7
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IL7000OL
Coding: 000036
VCID: 3D7A34821D19
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 J HW: 8T0 920 981 J
Component: KOMBIINSTR. H34 0255
Revision: 00000000 Serial number: CI055F1D9
Coding: 831701000300D705020000
VCID: 438E427A7BFD
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E09B25023A
Coding: 00C303
VCID: 52A0773EB487
Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001010039379
VCID: 438E427A7BFD
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 8T0 959 793 J HW: 8T0 959 793 D
Component: TSG FA H07 1201
Coding: 011C03224000120102
VCID: 50A47D36BA8B
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0124561155
Coding: 0106069A007A440400B0003200000000
VCID: 78F4E59672BB
Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 8T0 959 792 J HW: 8T0 959 792 D
Component: TSG BF H07 1201
Coding: 011C03224C00120102
VCID: 4FA67E4AA7B5
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000517103
Shop #: WSC 00000 000 00000
VCID: 346C11A62E53
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: F7F666AAFFA5
Address 56: Radio (R) Labels: None
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335L+097542844
Coding: 020000020100000001
VCID: 1D3AD402BDD9
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 8T1 035 664 B HW: 8T1 035 664 B
Component: H-BN-NA H47 0042
Revision: -------- Serial number: 490LW097540511
Coding: 010200020006E1EF05000B0E000000030000
VCID: 377626AA3F25
Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 13702 km
Time Indication: 0
Date: 2010.07.11
Time: 18:12:31
Freeze Frame:
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 00000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J9Y91CQ
Coding: 1000008
VCID: 38742596323B
End ---------------------------------------------------------------------
Defeated
Acura TL type-s
Mercedes C300 4-matic
Porsche Cayman S
Infiniti G37S
Older Model BMW (3-series)
Cars:
2010 Audi A5 3.2L-Black/Black (2-28-10)
2005 SL500 Sport-Black/Charcoal (3-22-09)
2004 A6 3.0 quattro-Dark Blue/Black
1998 A8 4.2-Black/Black (given away)
xxkazxx is offline   Reply With Quote
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
