#1 |
Junior Member
Hi All, been lurking in the forums for a while and I'm seriously considering purchasing a 2010 S5 in the US. I've searched the forums and haven't found the info I'm looking for so I'm hoping some experienced users can chime in!
Audio Inputs / Cables : I've read that there are several cables for porting audio into the MMI system. iPod, Mini-USB. Is there a 3.5mm stereo aux-in cable for other devices (I have a Kindle 2 and use the text-to-speech feature through the headphone jack in my existing car quite a bit...) Is the cable interface port in the glovebox the only way to access the auxiliary port? Can you have more than one cable hooked up at a time (so I wouldn't have to manually switch between iPod and a stereo cable...) iPod Functionality : How does the 3G MMI access the iPod? I know in many current cars, their iPod "support" is limited to just scrolling through and playing off the Playlists. Can you navigate all of the metadata (Artist, Album, Songs, etc.?) Do you find it well thought-out or is it cumbersome to use? USB Functionality : I love the idea of being able to put a good size HD in the glovebox and play all of my music off there. How do you access the data on it through the MMI? Is it via a folder hierarchy? Similar to my question on the iPod, do you find it easy to navigate? Video Inputs : I've played around with Computers in my last couple of cars and loved the ability to display all of my tv shows, movies, music, etc. on the car's navigation screen. Is there a cable to bring video into the system and use the nav screen to display an external source? Thanks for your time, really looking forward to hopefully picking up my new ride soon! |
| Sponsor - Register now for free to stop viewing this ad. |
#2 |
Super Moderator
Welcome to the forums.
In answer to most of your questions - yes! See responses below: Is there a 3.5mm stereo aux-in cable for other devices - YES Is the cable interface port in the glovebox the only way to access the auxiliary port? - YES Can you have more than one cable hooked up at a time - NO Can you navigate all of the metadata (Artist, Album, Songs, etc.?) - I think so, Yes (but someone else will confirm) Do you find it well thought-out or is it cumbersome to use? - Most folks have found it fine. How do you access the data on it through the MMI? Is it via a folder hierarchy? - YES Similar to my question on the iPod, do you find it easy to navigate? - Most have found it fine. Is there a cable to bring video into the system and use the nav screen to display an external source? - You can transfer your files to a HD and use the Mini-USB or USB cable to stream video (in certain formats.
__________________
- Zee His arrived 25 Feb 2010: 2010 Audi S5 | Sprint Blue | Alcantara | Black Optic | B&O | BBS | Eibach | B&B | Stasis | H&R | K&N | PIAA | E-codes | OEM mods | Tint Hers arrived 29 Dec 2009: 2010 VW Golf | TDI | Black | Black | OEM Mods | Tint Been there, Done that: Silverstone F1 circuit, Spa Francorchamps, Donnington Park, Virgina International Raceway and the mighty Nürburgring Last edited by zee007; 12th March 2010 at 05:30 AM. |
#3 |
Junior Member
Hi Zee,
Thanks so much for your quick response! Of course, your answers lead to more questions! Is there a 3.5mm stereo aux-in cable for other devices - YES (Is this included with the car or a separate purchase through the dealer? Same goes for the mini-usb?) Is the cable interface port in the glovebox the only way to access the auxiliary port? - YES Can you have more than one cable hooked up at a time - NO Can you navigate all of the metadata (Artist, Album, Songs, etc.?) - I think so, Yes (but someone else will confirm) Do you find it well thought-out or is it cumbersome to use? - Most folks have found it fine. How do you access the data on it through the MMI? Is it via a folder hierarchy? - YES Similar to my question on the iPod, do you find it easy to navigate? - Most have found it fine. Is there a cable to bring video into the system and use the nav screen to display an external source? - You can transfer your files to a HD and use the Mini-USB or USB cable to stream video (in certain formats.) (Can anyone elaborate on the formats supported? Divx? Xvid? MP4?) Anyone ever try to pair more than one Bluetooth device at the same time? Thanks again! |
#4 |
Super Moderator
The 3.5mm Jack is available as an option (like $50 here in the US). Some people have got multiple leads from their dealer when the car arrived, some none, some 1. Depends. I got the Ipod cable only. Other have had the USB or mini-USB and Ipod. Worth asking.
File Formats: MMI 3G: MP3 (MPEG-1 Layer 3, MPEG-2 Layer 3), WMA files (Version 7, 8, 9), and AAC files (MPEG-4) MMI Radio Plus: MP3 (MPEG-1 Layer 3, MPEG-2 Layer 3), WMA files (Version 7, 8, 9) Radio Symphony: M3U, PLS, ASX, and WPL Radio Concert: M3U, PLS, ASX, and WPL
__________________
- Zee His arrived 25 Feb 2010: 2010 Audi S5 | Sprint Blue | Alcantara | Black Optic | B&O | BBS | Eibach | B&B | Stasis | H&R | K&N | PIAA | E-codes | OEM mods | Tint Hers arrived 29 Dec 2009: 2010 VW Golf | TDI | Black | Black | OEM Mods | Tint Been there, Done that: Silverstone F1 circuit, Spa Francorchamps, Donnington Park, Virgina International Raceway and the mighty Nürburgring |
#5 | |
Senior Member
Quote:
http://a6retrofit.tripod.com/article...oplayback.html
__________________
My A5 retrofit links: A5 VAG COM codes list http://a6retrofit.tripod.com/articles/a5vagcodes.html A5 "real" MMI vs. radios explained http://a6retrofit.tripod.com/articles/a4a5realmmi.html AMI parts/retrofit http://a6retrofit.tripod.com/articles/a4a5amiparts.html Homelink retrofit http://a6retrofit.tripod.com/articles/homelink.html Voice control retrofit a6retrofit.tripod.com/articles/a4a5a6voicecontrol.html Add oil dipstick a6retrofit.tripod.com/articles/a4a5oildipstick.html |
#6 | |
Junior Member
Quote:
FYI, in the US, the S5 is delivered with with IPOD cable.
__________________
Fael 2010 Audi S5 | Tip | Prem+ | Ice Silver | Magma Red | Sport Diff. | B&O | Nav 2008 Audi A6 | 3.2 CVT | Prem+ | Quartz Gray | Nav |
| Tags |
| 3g mmi, audio inputs, ipod, s5/a5, video inputs |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
