Starting problems after clutch issue - Audi A5 Forum & Audi S5 Forum
post #1 of 35 Old 28th November 2016, 05:36 PM Thread Starter
GibDTD's Avatar
Unhappy Starting problems after clutch issue
Hi everyone,
I have a 2011 S5 with a 4.2L and manual transmission. Last week my clutch gave out and left me stranded for a few hours. I had it towed to my mechanic that night and I started to the car to keep warm. The mechanic went to take a look the next morning and the car would not start.
Since then I got the car home, replaced the clutch slave cylinder, bled the system. I figured once the system was closed and functioning properly again the car would start right up. Unfortunately, it has not started right up. I get dash lights, overhead lights, MMI functionality, and all the normal stuff, but the car will not start.
Is there something I need to reset with a computer before it will start again? What other are other possible reasons for the car not starting? It started and ran fine the rest of the day after the clutch gave out.
Thanks in advance.
David
GibDTD is offline
post #2 of 35 Old 29th November 2016, 11:01 AM
Quoted: 38 Post(s)
Check the clutch switch by the pedal and can you scan it with vcds?
Audi A6 BiTdi Avant
morski is offline
post #3 of 35 Old 29th November 2016, 11:23 AM
danjwilson's Avatar
Quoted: 340 Post(s)
If it's the switch on the clutch pedal not quite making, I'd have thought that the DIS message asking the driver to depress the clutch pedal would come up when attempting to start (even though it is pressed)?
Sent from my iPhone using Tapatalk Pro
Dan.
A5 3.0TDI quattro Coupe Blk Ed+ S-Tronic - Daytona Grey - 3G+MMI Nav, B&O, DAB, AMI, 19" Gloss Black 'Y' Design, Auto Dim RVM, Elec. Folding & Auto Dim Mem Mirrors, Cruise, Black Leather/Alcantara Elec Memory Seats, Bluetooth, LED Light Pack, Xenon Plus & LED DRL's, High Beam Assist, Parking System Advanced, Adv. Key, ADS, Adaptive Dampers, Privacy Glass, Storage Pack, BlackVue
Previous - A5 3.0TDI quattro, Blk Ed, S-Tronic - Glacier
Previous - A5 3.0TDI quattro Sport Coupe - Silver
danjwilson is online now
post #4 of 35 Old 30th November 2016, 09:02 AM
almostS50's Avatar
Quoted: 98 Post(s)
Did they change the throw out bearing?
2008 coupe manual, H&R sway bars front and rear-custom eurocode endlink fornt spherical bushing rear,Miltek sport non-resonated exhaust with downpipes, RS5 grill,stratmosphere short shifter, Stoptech 380 bbk carbotech xp12 front rear, Olins track coilovers,APR supercharger Apr cold air intake, TTRS flat bottomed steering wheel, custom separate reservoir clutch fluid, BBS chr wheel with advan neovas, RS5 oval tailpipes, Recaro CS seats with Schroth racing harness, K40 radar front rear
almostS50 is offline
post #5 of 35 Old 1st December 2016, 12:09 PM Thread Starter
GibDTD's Avatar
I did not check the switch by the pedal and I am not getting a message to depress the clutch to start it. I will give it a look real quick while I'm under there changing the clutch master.
I do not have a VDCS, but I have scanned it with a Bluetooth to phone scanner and it showed no codes at all.
**Edit: Throwout bearing has not been changed yet, only the slave. **
I see on the new clutch master that there is a sensor on the top of it, if the master was run dry of fluid from sitting, might that sensor not allow the car to start?
GibDTD is offline
post #6 of 35 Old 1st December 2016, 04:32 PM
jwr9152's Avatar
Quoted: 18 Post(s)
As Scott said. Throw out bearing. It should always be changed when you change the clutch.
2011 S5 APR stage 3 supercharger, APR tune, B&B exhaust, Bilstein PSS10 B16, 034 strut mounts, SPC adjustable control arms, USS sway bars and end links, JHM lightweight flywheel and clutch, JHM short shifter, 034 transmission mount, Stoptech BBK, alu kreuz, 034 intake, apikol differential mount, AWE S-flo filter, cr-15 strut brace
jwr9152 is offline
post #7 of 35 Old 2nd December 2016, 02:09 AM
themirror178's Avatar
It's a combination of the master cylinder and throwout bearing that causes the not starting. You should still be able to start it by burying the clutch pedal (like REALLY hard into the carpet). This will get worse and worse, so go get your clutch changed (including pp and throw out bearing and master cylinder)
'08 S5 6MT
themirror178 is offline
post #8 of 35 Old 3rd December 2016, 07:57 AM Thread Starter
GibDTD's Avatar
Here the thing though, it's not the clutch, the clutch has not been changed. The Clutch Master Cylinder and the Clutch Slave Cylinder have both been replaced and I changed the line between them to the USP stainless steel line.
Before the clutch slave cylinder seal blew there were no issues with the clutch itself. I did not have to push the pedal through the floor, I didn't have problems starting it.
I feel the issue is that the clutch system was drained of fluid due to the broken seal which may have triggered a sensor which is preventing the car from starting.
GibDTD is offline
post #9 of 35 Old 3rd December 2016, 12:57 PM
Ah sorry I misread your post, didn't realise yours is 2011, so shouldn't have the usual clutch issues like the older cars..
I believe their is only a sensor on the master cyl. to start the car.
Does the clutch pedal feel the same as before?
Perhaps check near the master cyl for leaks, in case a seal blew near there too. Check brake fluid reservoir isn't empty, cap is on (there is a sensor on the cap, but not sure what it does)
'08 S5 6MT
post #10 of 35 Old 3rd December 2016, 04:00 PM Thread Starter
GibDTD's Avatar
The sensor on the brake reservoir is a fluid level sensor, the level is good. I just replaced the master, line and slave cylinders, no leaks drips spots or anything. The pedal does have a spot up near the top of its travel that is soft, but the rest is good and firm. Overall it's a little softer than it used to be but not much.
I tested the battery, it was weak, down to 275 CCA. Its supposed to be up near 850 CCA. After removing it, charging it and reinstalling it, there is no change. Car won't start, MMI works, lights come on and off like normal, key fob locks and unlocks doors.
GibDTD is offline
post #11 of 35 Old 4th December 2016, 02:40 AM
Can't think of much else sorry. There is a connector for the gear selection near the transmission case, not sure how that'd affect starting, but maybe double check that? Have you tried unplugging the master cyl. connector and making sure the terminals and wires are all OK? I highly recommend VCDS though.
'08 S5 6MT
post #12 of 35 Old 4th December 2016, 04:33 PM
jwr9152's Avatar
Quoted: 18 Post(s)
Guess I misread your post too. Thought you had replaced the clutch and not the throw out bearing. Sorry. A Ross-tech could tell you if everything is communicating.
jwr9152 is offline
post #13 of 35 Old 7th December 2016, 12:31 AM Thread Starter
GibDTD's Avatar
I plugged in a VCDS, scanned and cleared DTCs. All have gone away except one. The last one in in Module 8, HVAC stuff. The code is,
01206 - Signal for duration of ignition off time
Then a little further down it says starter relay. I am in the process of getting a new starter relay and will try again once I have a new one installed.
I will get the full fault code and edit it in above later.
GibDTD is offline
post #14 of 35 Old 7th December 2016, 03:19 AM
Good luck, keep us updated.
'08 S5 6MT
post #15 of 35 Old 7th December 2016, 12:58 PM Thread Starter
GibDTD's Avatar
This is the code I got last night. I did a little digging and the Ross-tech page recommended replacing the starter relay first. I went to Audi today and purchased a starter relay, installed it and still no good.
Other possible causes were broken links between the climate control and instrument panel, broken instrument panel, or broken climate control.
Does anyone know if the clutch master has to be in a certain position (i.e. sensor up as opposed to on a 90 angle)?
I am getting very frustrated and I am ready to trade it in for a Dodge Challenger GT if I can't fix this.
GibDTD is offline
post #16 of 35 Old 8th December 2016, 11:45 AM
Can you copy and paste all the fault codes here?
'08 S5 6MT
post #17 of 35 Old 8th December 2016, 03:30 PM Thread Starter
GibDTD's Avatar
Sure can, I have two scans that I saved. The first (below) is before I cleared the DTC's.
Tuesday,06,December,2016,16:39:50:35838
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: WAUGVAFRXBA002618 License Plate:
Mileage: 166070km-103191mi Repair Order:
Chassis Type: FR (8T0)
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
6C
VIN: WAUGVAFRXBA002618 Mileage: 166070km-103191miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CAUB) Labels: 079-907-560-CAU.clb
Part No SW: 8T0 907 560 AE HW: 8T0 907 560
Component: 4.2l V8/4V H17 0002
Revision: 76H17---
Coding: 01140009180F0120
Shop #: WSC 11903 002 1048576
VCID: 7DFBE0ABE47A90AAA2-8028
2 Faults Found:
012424 - Starter Relay
P3088 - 001 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 166074 km
Time Indication: 0
Date: 2010.01.22
Time: 00:11:57
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 6.0C
Temperature: 7.0C
Absolute Pres.: 1010.0 mbar
Voltage: 12.573 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0C
Temperature: -40.0C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0110 1101
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0050
Revision: -------- Serial number: --------------
Coding: 110D18
Shop #: WSC 06325 000 00000
VCID: 020193579D84EF52DF-8056
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 0B0000
VCID: 76E9FF87C14CC3F2E3-8022
Subsystem 1 - Part No SW: 8T0 959 754 M HW: 8T0 959 754 M
Component: FBSAUDIB8 IDG H50 0070
Serial number: 0510000029597018
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000082088003
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001002002024
Coding: 00017025002C00000000
VCID: 438F5653C21E265A94-8016
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01310520100319
Coding: 48122000
VCID: 0005995F9388FD42C9-8054
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Mileage: 166074 km
Time Indication: 0
Date: 2010.01.22
Time: 00:00:31
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0392
Revision: 10029001 Serial number: 00000000552763
Coding: 26001091063CAF010000080300003D3D0F1C13880201016100 0000
VCID: 3C7D2DAFBFE059A2D5-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 040510 H14 0070
Serial number: SWF10050040919
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10923935
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Serial number: 00000000001305101640
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241014819332
Coding: 200002
VCID: 47974243F6260A7A48-8012
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H41 0610
Serial number: 003GLD0G2Z1L
Coding: 303338334330303030304A55304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 458B484BC42A186ABA-8010
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R0000007AL6
Crash sensor for side airbag: driver side:
Serial number: 6334MSME5341773CF
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME53614C26D
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME5C62502EN
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME4E634E2C.
Crash sensor for front airbag: driver side:
Serial number: 63732SME61625730T
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME6162572E0
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H06 0156
Revision: 00000000 Serial number: 20100601000187
Coding: 000016
VCID: 4993447BE032FC0A5E-801C
Component: E221 - MFL H02 0010
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 207
Mileage: 166075 km
Time Indication: 0
Date: 2016.11.24
Time: 09:59:20
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 983 D HW: 8T0 920 983 D
Component: KOMBIINSTR. H38 0258
Revision: 00000000 Serial number: EI1659L5A
Coding: 8B1501000300D705020000
VCID: 3F875AA3AEF642BAF0-806A
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E105208029
Coding: 00C303
VCID: 030F9653829EE65AD4-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1001B9F9190510
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 207
Mileage: 166074 km
Time Indication: 0
Date: 2010.01.27
Time: 06:27:04
Freeze Frame:
Bin. Bits: 10111
Voltage: 10.60 V
Count: 6
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001002001797
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C03224000120102
VCID: 53AF6613327EB6DA24-8006
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 165574 km
Time Indication: 0
Date: 2016.11.22
Time: 06:40:13
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0130596638
Coding: 0106029A00FA444480B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000258577
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Serial number: 0123456789ABCDEFGHIJ
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882002695801
VCID: 7AF1EBB7F554A79287-802E
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52A163170D64BFD22F-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000525998
Shop #: WSC 00000 000 00000
VCID: 346D058F97B091E21D-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: 77F7F2830646BAFAF8-8022
1 Fault Found:
01312 - Powertrain Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 207
Mileage: 166074 km
Time Indication: 0
Date: 2010.01.22
Time: 00:01:15
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H51 0133
Revision: AB001007 Serial number: 471EY0A7504259
Coding: 020007010000000001
VCID: 244DF5CF275001628D-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 F HW: 8T1 035 664 B
Component: H-BN-NA H49 0189
Revision: -------- Serial number: 490E/0A7568515
Coding: 010200020206A1EF41000B0E000000030000
VCID: 3B7F2EB3BAEE5E9ADC-806E
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H42 0098
Serial number: 9466FO0A0008117
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000553083
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
1 Fault Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 38
Mileage: 156000 km
Time Indication: 0
Date: 2010.01.27
Time: 00:33:05
Freeze Frame:
Voltage: 11.40 V
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H04--- Serial number: 525PA8-J0392MR
Coding: 1000008
VCID: 387531BF4BD8758231-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 207
Mileage: 166075 km
Time Indication: 0
Date: 2016.11.24
Time: 09:59:14
Freeze Frame:
Term 15 On
Reverse ON
Count: 3
End-------------------------(Elapsed Time: 03:06)--------------------------
GibDTD is offline
post #18 of 35 Old 8th December 2016, 03:38 PM Thread Starter
GibDTD's Avatar
The second (below) is after I cleared the DTC's, but had not yet tried to start the car. Since clearing the DTC's I have changed out the starter relay and replaced the battery with a new unit from Audi. Unfortunately I do not have access to the VCDS at the moment to scan again and give the most up to date code issues.
Tuesday,06,December,2016,16:47:14:35838
Ross-Tech: Home
6C
Revision: 76H17---
Coding: 110D18
Revision: 00002001
Coding: 0B0000
Coding: 48122000
Coding: 00FD11
Coding: 02532C
Coding: 200002
Coding: 000016
Coding: 00C303
Coding: 0000002
Coding: 1000008
End-------------------------(Elapsed Time: 03:27)--------------------------
GibDTD is offline
post #19 of 35 Old 9th December 2016, 01:32 PM Thread Starter
GibDTD's Avatar
Some good news, kinda... We push started it today and it started up and ran perfectly. It went through the gears nicely too. When I pulled in the driveway and shut it down and tried to restart it, it wouldn't start again.
Bittersweet victory.
GibDTD is offline
post #20 of 35 Old 9th December 2016, 05:42 PM
Congrats! I googled your "P3088 - 001 - Electrical Malfunction" and there's a thread about a starter issue. I'm not sure if the starter connection is accessible without removing too much, but when you start it, do you here the (new) relay "click"? If you have a voltmeter, check to see if the starter is getting power at the terminals perhaps.
'08 S5 6MT
post #21 of 35 Old 10th December 2016, 04:13 AM Thread Starter
GibDTD's Avatar
The new starter relay does click but I hear nothing from down near the starter. From what I can see, it is really hard to get to the starter from the bottom side but I may have a little more access from the top if I remove the airbox. Replacing the starter looks like its going to be a big pain too and that there are other things I should do at the same time because of convenience. Starter Removal Audi S5 V8 FSI
Can anyone get a wiring diagram (with fuses and relays) for the starter system? Id like to make sure there are no blown fuses or a missed ground before I start an 11+ hour job replacing the starter.
GibDTD is offline
post #22 of 35 Old 10th December 2016, 03:29 PM
Do you have access to alldatadiy? There's no one diagram, but it does seem to have quite a bit of info on grounding locations.
I got this from them for grounding points of the car:
'08 S5 6MT
post #23 of 35 Old 10th December 2016, 03:51 PM Thread Starter
GibDTD's Avatar
I do not have direct access to alldatadiy. This diagram does give me a good starting point to start looking for a bad ground.
I guess if you have access, could you get a breakdown of the fuse/relay box under the hood behind the firewall? And maybe an engine wiring diagram, especially the starter wires.
Thank you themirror178
GibDTD is offline
post #24 of 35 Old 10th December 2016, 06:13 PM
jwr9152's Avatar
Quoted: 18 Post(s)
Unbelievable that the engine and transmission has to be dropped to change out the starter. Might as well do all sorts of things while everything is out. Hopefully in your case it's not a full starter replacement.
jwr9152 is offline
post #25 of 35 Old 10th December 2016, 08:16 PM
I can't seem to find a list of what each fuse is unfortunately. The diagrams are split into 30 pages - I do suggest you purchase it ($17) and perhaps you can make out what each fuse is. Here's the diagram for the starter, might be useful:
ws = white
sw = black
ro = red
br = brown
gn = green
bl = blue
gr = grey
li = lilac
ge = yellow
or = orange
rs = pink
B - Starter
C - Generator
C1 - Voltage regulator
J533 - Data bus on board diagnostic interface See: Locations\Overview of control modules in interior of vehicle - Coupe (2-door models)
S204 - Fuse 1 (terminal 30) See: Locations\Overview Of Fuses
S205 - Fuse 2 (terminal 30) See: Locations\Overview Of Fuses
T5l - 5-pin connector, in the engine compartment
T17e - 17-pin connector, red See: Power and Ground Distribution\Locations
T17q - 17-pin connector, black See: Power and Ground Distribution\Locations
T17r - 17-pin connector, white See: Power and Ground Distribution\Locations
T20d - 20-pin connector
TV22 - Terminal 30 wire junction 2
U6 - Battery jump start terminal
(D97) - Connection (50) (in right engine compartment wiring harness)
* - Refer to applicable coolant fan wiring diagram
'08 S5 6MT
post #26 of 35 Old 11th December 2016, 06:52 AM
almostS50's Avatar
Quoted: 98 Post(s)
good news is you found your issue, bad news is you'll have to drop the tranny-been there done it! but at least you have a running S5
post #27 of 35 Old 11th December 2016, 08:46 AM
Quoted: 39 Post(s)
These fuses are for ventilators.
2011-??: S5 4.2 FSI manual, auxilliary heater, keyless, memory seats, navi, rear cam, etc.,
upgrades: chiptuning, Vmax off, Milltek resonated exhaust, VCDS mods (ADS, TPMS, highway lights), ADS switch, RS5 pedals, Bluetooth, LED rear lights, OZ Racing Superturismo Le Mans wheels (graphite grey).
2007-2011: A5 3.0TDI Quattro Sportmotor edition, KW V2, Caractere, OZ Ultraleggera HLT 19'', chiptuning 220kW, K&N, Milltek, LED, RS5 pedals, lots of VCDS mods
post #28 of 35 Old 11th December 2016, 08:59 AM
Quoted: 39 Post(s)
This says it all:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 207
Mileage: 166075 km
Time Indication: 0
Date: 2016.11.24
Time: 09:59:20
First I would charge battery, it's the most common problem why car doesn't start.
post #29 of 35 Old 17th December 2016, 02:34 PM Thread Starter
GibDTD's Avatar
What?
This says it all:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 207
Mileage: 166075 km
Time Indication: 0
Date: 2016.11.24
Time: 09:59:20
Battery has been changed for a brand new one from Audi and the issue remained. I also changed out the starter relay with the same results.
Update, I have decided to tackle the job of replacing the starter and let me tell you, it is a lot of work. I found a "write up" on audizine that I've been using as a guide.
After 6-7 hours of disassembling things and struggling to remove things from tight spaces I have finally gotten to the starter. I have the lower bolt out and will resume removing the upper bolt tomorrow when there is more light. During disassembly I discovered my passenger side motor mount was torn and leaking fluid. That is now on order and should be here Wednesday or Thursday so hopefully I will be driving my car again by Christmas. Being tight on funds at the moment due to all the above issues, I decided to order the Hamburg Tech motor mounts from ECS. Has anyone heard any good or bad about these?
GibDTD is offline
post #30 of 35 Old 17th December 2016, 04:10 PM
Thanks for the update, admire your effort to tackle this yourself!
The OEM motor mounts seem to be terrible, I got mine changed to 034 motorsport ones when doing the clutch as they were leaking too. Can't comment on the Hamburg ones, but can recommend 034. Solid filled, so I don't have to worry about it leaking fluid and should hopefully last a while.
Good luck with it all.
'08 S5 6MT
