Starting problems after clutch issue - Page 2 - Audi A5 Forum & Audi S5 Forum
post #31 of 35 Old 26th December 2016, 07:57 AM Thread Starter
GibDTD's Avatar
Final update: The starter was removed and tested bad. It has been replaced with a new Bosch replacement starter. The car is back together and I only have 4 bolts left over! They're all bumper bolts so I'm just sorting out which ones go where.
The beast is alive! It starts and runs under its own power again and I can't wait for the snow to start falling again.
Thanks you everyone for your help, it definitely helped me narrow down the cause of the problem and address it properly.
jwr9152 likes this.
GibDTD is offline
post #32 of 35 Old 26th December 2016, 02:30 PM
themirror178's Avatar
Congrats! Any tips/gotchas for replacing the starter?
themirror178 is offline
post #33 of 35 Old 1st January 2017, 02:40 PM Thread Starter
GibDTD's Avatar
I took some pictures during the process, I was thinking of doing a write-up on how I tackled the job, but I am still having issues.
I forgot to tighten down a ground so it started three times but wouldn't start the fourth. This issue has been resolved now but along with it came some codes. I had to use a crappy U-scan device but it gave me the codes I need. My biggest concern or what I believe to be the cause of the current problem is a P0414 code and the description is Secondary Air Switching Valve A Circuit Short. All the other codes are "circuit low" codes. See attached images for all the codes.
GibDTD is offline
post #34 of 35 Old 9th January 2017, 07:12 AM Thread Starter
GibDTD's Avatar
Took it to Audi to have them diagnose the issue. $240 later, it turns out the motor mount is shorting out. I disconnected it for now and will replace with something else soon.
GibDTD is offline
post #35 of 35 Old 10th January 2017, 12:16 PM
You replaced it with MT mounts right? I'm pretty sure they're solid filled, so they should have a dummy resistor inside it. You could probably hack it up and leave it disconnected, but the electrical connector connected to a resistor in series
'08 S5 6MT
