Looking for standart VCDS codes for tail lights A5 2015 - Audi A5 Forum & Audi S5 Forum
  • 1 Post By bpodnar
post #1 of 24 Old 11th May 2017, 11:33 PM Thread Starter
Hey, guys!
My car is Audi A5 coupe 2015.
As the title says, I bought the VCDS cable to code some features on my car, everything was going well until I went to the tail light coding. My goal was to make it like the US tail light (Turn Signal+Stop Signal) instead of EU (Just turn signal) ones I have. I messed with the codes, now I got the rear turn signals lighted permanently, it looks ridiculous.
I went to COMFORT MODULE [46]
SECURITY CODE: 16017
CHANNELS RESPONSIBLE FOR THE TAIL LIGHTS CODING: 195 – 210 - But I changed only 195 to 198.
Now my question is could somebody provide me the STANDART factory codes, so I can get it back?
Big thanks, long live A5
Hustler33 is offline
post #2 of 24 Old 12th May 2017, 11:33 AM
bpodnar's Avatar
Quoted: 29 Post(s)
Just look in vcds installation folder you have log of all changes you made. Simple as that
Audi always and forever!
bpodnar is online now
post #3 of 24 Old 13th May 2017, 07:16 AM Thread Starter
Big thanks! But how to? Any screenshots?
post #4 of 24 Old 13th May 2017, 12:10 PM
bpodnar's Avatar
Quoted: 29 Post(s)
Well, it is txt file located in c:/vcds. Im sure you are able to find it because its elementary knowledge
post #5 of 24 Old 14th May 2017, 05:33 AM Thread Starter
Did just like you said, it changed the way the taillights look, but not like it was. Right now the turn signal is always on with a couple of stop signal blocks.
post #6 of 24 Old 14th May 2017, 07:15 AM
i wrote the guide attached when i was doing a retrofit of my 2010, the new coding values may be of assistance
A5 Mods: front end retrofit, Parking plus, ADC, flat bottom steering wheel, S5 interior, Rotor wheels, FL Rear LEDs, interior lighting pack, folding wing mirrors, auto dimming mirror
jonneyflame is offline
post #7 of 24 Old 14th May 2017, 08:27 AM Thread Starter
Thanks, Jonney! I should use the "New value" from the "This is for Pre facelift LED to face lift LED:", right?
post #8 of 24 Old 14th May 2017, 09:51 AM
thats right, the new values should be the same as your originals, i would make a note of the old values before you change them just to be on the safe side.
good luck
post #9 of 24 Old 16th May 2017, 03:50 AM Thread Starter
good luck
Unfortunately, you codes didn't worked. Maybe I need to clear it out for everyone, that I didn't modified my taillights. My car wasn't modified, it's 100% stock. I just wanted to change the way my tail lights work and I messed up. I tried the codes from AdpLog from VCDS folder - didn't worked.
Some further assistance anyone?
post #10 of 24 Old 16th May 2017, 05:38 AM
Quoted: 59 Post(s)
Someone with factory fitted FL LED's has to make an adpmap for you.
Contact me for rear light LED adapters and other wire harnasses for retrofitting. (RS5 rear spoiler, heated seats, PDC etc etc)
Baas J. is offline
post #11 of 24 Old 16th May 2017, 06:05 AM
bpodnar's Avatar
Quoted: 29 Post(s)
I have european FL LHD with led lights, what code I need to read for you in vcds?
post #12 of 24 Old 16th May 2017, 06:56 AM Thread Starter
Thanks, man! From 181-213, I guess, cuz I messed it up pretty well
post #13 of 24 Old 16th May 2017, 10:20 PM
Quoted: 59 Post(s)
VCDS ---> Applications ---> controller channel map, enter controller address and securitycode and choose "CSV".
Baas J. is offline
post #14 of 24 Old 17th May 2017, 02:26 AM Thread Starter
Could you please describe what it does?
post #15 of 24 Old 17th May 2017, 04:22 AM
Quoted: 59 Post(s)
It creates an Excel with all 255 channels, so you can compare.
Baas J. is offline
post #16 of 24 Old 17th May 2017, 08:29 AM
bpodnar's Avatar
Quoted: 29 Post(s)
I managed to read only channel 194 which iz value 7. Others channels are not readable.
post #17 of 24 Old 17th May 2017, 09:20 AM
bpodnar's Avatar
Quoted: 29 Post(s)
I have realised just now that you have used different security access code. I was using 22790 which is default, sorry. Will try again tommorow with 16017 and read adaptation codes.
post #18 of 24 Old 17th May 2017, 11:44 PM
bpodnar's Avatar
Quoted: 29 Post(s)
Here is a list of codes, mate
congo likes this.
post #19 of 24 Old 18th May 2017, 08:08 AM Thread Starter
Aight, will do! Thanks, man!
post #20 of 24 Old 18th May 2017, 08:09 AM Thread Starter
G'eah, huge thanks, man! Much appreciated! Will try that 2day, I'll write my experience right here
post #21 of 24 Old 19th May 2017, 04:34 AM Thread Starter
Hey, man! Your codes worked like a charm, thank you. Big respect to you not being a lazy butt and helped me!
post #22 of 24 Old 19th May 2017, 06:05 AM
bpodnar's Avatar
Quoted: 29 Post(s)
which channel did you changed exactly and what was your intention to get?
post #23 of 24 Old 20th May 2017, 01:02 PM Thread Starter
I changed all the channel to digits from your post and it's back to regular now
post #24 of 24 Old 20th May 2017, 01:20 PM
bpodnar's Avatar
Quoted: 29 Post(s)
I was asking about your previous activity when you f*cked up all the channels. What did you want to achieve? Brake lights to blink together with turn signals or?
