EGR valve replacement - Audi A5 Forum & Audi S5 Forum
 2Likes
  • 1 Post By Dave Kwatro
  • 1 Post By Vitalchip
post #1 of 6 Old 18th April 2017, 02:43 AM Thread Starter
I'm looking to replace my EGR valve with a new one as i want to sortr it out before it gets sticky as i've done over 130,000 miles thus far.
Surfing ebay i see EGR valves for left hand side & ones for the right hand side, EGR controller, EGR solenoids, EGR control flap (is this part of the valve?) ones that are metal & others that are plastic.........etc etc
Is there more than one EGR valve in a 3.0tdi?
Do ones for the 2.7tdi or 4.0tdi fit the 3.0?
Whats the part number i'm looking for & does anyone have a pic for what i'm after so i can compare to the ones i'm seeing on ebay & other web pages?
Thanks in advance
R1CSO is online now
post #2 of 6 Old 18th April 2017, 03:36 AM
Eamonn's Avatar
Quoted: 123 Post(s)
Do you know your engine code? If it's CCWA, I had mine changed recently and I'll dig out the receipt for you. I'm reasonably sure it had the part number on the receipt
Beep beep.
Eamonn is online now
post #3 of 6 Old 18th April 2017, 06:07 AM Thread Starter
Mine is CAP
R1CSO is online now
post #4 of 6 Old 21st April 2017, 03:35 AM
Quoted: 37 Post(s)
A new EGR for the 3.0TDI is about £300! It's water cooled etc etc. If there is nothing wrong with it at present, leave it and use decent fuels, not cheap supermarket crap, or run Millers Diesel Sport through the fuel, the less soot your engine produces, the less problems.
R1CSO likes this.
post #5 of 6 Old 26th April 2017, 10:55 AM
Vitalchip's Avatar
Quoted: 14 Post(s)
I've been dealing with mine recently CAPA engine.
There is a motor driven valve which controls the flow of exhaust gas and a solenoid/vacuum pusher that controls the path of the gas through the cooler (or not).
They are a lot of work to get out but you can get to the front of the EGR valve a bit easier and get some carb cleaner into it.
You need to take off the inlet piping, which will mean taking off the high pressure fuel lines from the pump and a few other bits and pieces, then you can undo the braided EGR pipe and clean the valve from the front and from the top by removing the plastic cover containing the motor and pot connections.
Removing the entire valve and the cooler it quite a bit more involved.
R1CSO likes this.
A5 3.0TDi quattro, Aruba Blue.
Stuff I've done:
Fitted Cruise Control, Activated Ambient Lighting, Increased DRL Brightness When Sidelights ON. Shut Off Seat Belt Warning.
Vitalchip is offline
post #6 of 6 Old 28th April 2017, 07:42 AM
Quoted: 39 Post(s)
Don't change it, clean it ! The change doesn't help, there are intake manifiolds and egr lines full of carbon,
see pictures of 3.0TDI CAPA engine after 200000km/124274 miles Sportmotor dekarbonizace
2011-??: S5 4.2 FSI manual, auxilliary heater, keyless, memory seats, navi, rear cam, etc.,
upgrades: chiptuning, Vmax off, Milltek resonated exhaust, VCDS mods (ADS, TPMS, highway lights), ADS switch, RS5 pedals, Bluetooth, LED rear lights, OZ Racing Superturismo Le Mans wheels (graphite grey).
2007-2011: A5 3.0TDI Quattro Sportmotor edition, KW V2, Caractere, OZ Ultraleggera HLT 19'', chiptuning 220kW, K&N, Milltek, LED, RS5 pedals, lots of VCDS mods
