Hi everyone,
I'm new to this site and am hoping for advice from some of you petrolheads please.
I have a 5 yr old a5 sport back. Just had a recall sorted by Audi and they carried out the usual health check. Flagged up the following:
O/S/R shock absorber worn/leaking advise both replaced as pair £474
Front shock absorber worn/slightly leaking £471
75%PD rear brake pads 4.5mm plus discs req 10.5mm, min 10mm £469
They also say air con needs servicing which I haven't had done but is it necessary? Pollen filter has been changed.
So what I need to know is how soon I need all this doing. The Audi guy said it would pass mot so safe to drive but I guess I need to look at getting pads and discs done first? They do charge a lot and I will probably try a cheaper garage but unfortunately I am not able to pay out nearly £1500 in one go.
Any advice would be gratefully received!
Thanks in advance.
Thanks in advance.
