Back-up camera HELP - Audi A5 Forum & Audi S5 Forum
  • 1 Post By zspatak
post #1 of 8 Old 9th January 2017, 12:52 AM Thread Starter
Back-up camera HELP
Hi Guys,
I've recently retrofitted the back-up camera to my 2013 A5cab, and it works very nicely but the 03003 - Back-up Camera System not calibrated fault code left.
I've printed a calibration board and followed the Ross-Tech ( http://wiki.ross-tech.com/…/ind…/Aud...Back-Up_Camera ) procedure to calibrate the camera with the A5 value but it fails every time with error 0x0004 "Correction values out of range".
May I ask somebody who has facelifted A5cab with factory back-up camera could give me the factory value the followings chanels?
[6C - Back-Up Camera]
[Security Access - 16] Enter 22351, to enable the adaptation.
[Adaptation - 10]
Channel 005
Channel 004
or any idea?
thx
zs
zspatak is offline
post #2 of 8 Old 10th January 2017, 12:03 AM Thread Starter
come on Guys!
zspatak is offline
post #3 of 8 Old 10th January 2017, 02:58 AM
Quoted: 34 Post(s)
Why do you want to calibrate it? Does it work ok? I fitted to the my cab and it still needs calibrating but works perfectly fine
Audi A6 BiTdi Avant
morski is offline
post #4 of 8 Old 10th January 2017, 03:07 AM
Quoted: 33 Post(s)
Very coincidentally, I've also recently done the same retrofit. Well actually I had someone else come and fit the parts for me this time as I didn't want to spend the time. I regret this now as they didn't do as neat a job with the wiring as I would have done and they also didn't understand about the calibration so that didn't get done either which made it fairly useless for parking!
I got almost as far as you, and had a calibration image printed, but then it's been so cold and wet recently I just couldn't find a flat dry space to to try and set it up, so I gave in an paid my Audi dealer to do it. They charged me for half an hours labour, about £75. Works great now :-)
I don't know if you can copy the calibration values from one module to another, and miss out the step where the camera module 'sees' the chart on the ground (it may be using that for correcting the image distortion caused by the lens shape as well as position?)
I will try and do a full scan of all adaption channels on my module for you, in case there are any others that VCDS doesn't have names for.
2008 A5 3.0TDI quattro Tiptronic - 2012 A5 3.0TDI quattro S-Tronic Cabriolet
paradyne is offline
post #5 of 8 Old 10th January 2017, 03:11 AM
Quoted: 33 Post(s)
On mine, with a brand new un-calibrated control module, it was so far off that if you used the guide lines to reverse into a parking space you'd have crashed. When correctly calibrated I end up perfectly centred in the parking space or next to the kerb with undamaged wheels..
paradyne is offline
post #6 of 8 Old 10th January 2017, 03:44 AM Thread Starter
Thx, I'm waiting for your information
zspatak is offline
post #7 of 8 Old 10th January 2017, 03:48 AM Thread Starter
I'm an engineer!
Thats all!
paradyne likes this.
zspatak is offline
post #8 of 8 Old 15th January 2017, 05:33 PM
Quoted: 33 Post(s)
OK, sorry it took a while to get the scan data, don't know if this will help you but:
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H05--- Serial number: 525PA8-J1XB0DD
Coding: 1022009
Shop #: WSC 31970 001 1048576
VCID: E7D7A411D682EB7A9D-80B2
No fault code found.
;SW:8F0-907-441 HW:4L0-907-441-B --- Back-up Cam.
;Component:J772__Rearview 0040 Coding:1022009
;Sunday 15 January 2017 23:43:47:61375
;VCDS Version: Release 16.8.3 (x64) Data version: 20161010 DS267.0
;VCID: E7D7A411D682EB7A9D-80B2
Channel Field 1 Field 2 Field 3 Field 4
1 0 0 0 -4252 78
2 400 0 0 -4252 78
3 400 0 0 -4252 78
4 15748 0 0 -4252 78
5 578 0 0 -4252 78
6 ERROR: Channel 06 Not Available
7 ERROR: Channel 07 Not Available
8 ERROR: Channel 08 Not Available
9 ERROR: Channel 09 Not Available
10 50 50.00% 50.00% 50.00% 50.00%
11 50 50.00% 50.00% 50.00% 50.00%
12 50 50.00% 50.00% 50.00% 50.00%
13 50 50.00% 50.00% 50.00% 50.00%
14 0 1 0 0 0
15 129 N/A N/A N/A N/A
16 900 N/A N/A N/A N/A
17 1500 N/A N/A N/A N/A
18 ERROR: Channel 18 Not Available
19 ERROR: Channel 19 Not Available
20 ERROR: Channel 20 Not Available
21 ERROR: Channel 21 Not Available
22 ERROR: Channel 22 Not Available
23 ERROR: Channel 23 Not Available
24 ERROR: Channel 24 Not Available
25 ERROR: Channel 25 Not Available
26 ERROR: Channel 26 Not Available
27 ERROR: Channel 27 Not Available
28 ERROR: Channel 28 Not Available
29 ERROR: Channel 29 Not Available
30 ERROR: Channel 30 Not Available
31 ERROR: Channel 31 Not Available
32 ERROR: Channel 32 Not Available
33 ERROR: Channel 33 Not Available
34 ERROR: Channel 34 Not Available
35 ERROR: Channel 35 Not Available
36 ERROR: Channel 36 Not Available
37 ERROR: Channel 37 Not Available
38 ERROR: Channel 38 Not Available
39 ERROR: Channel 39 Not Available
40 31 N/A N/A N/A N/A
41 10114 N/A N/A N/A N/A
42 36836 N/A N/A N/A N/A
43 5912 N/A N/A N/A N/A
44 45663 N/A N/A N/A N/A
45 16671 N/A N/A N/A N/A
46 33311 N/A N/A N/A N/A
47 0 N/A N/A N/A N/A
48 36836 N/A N/A N/A N/A
49 54146 N/A N/A N/A N/A
50 54146 N/A N/A N/A N/A
51 54146 N/A N/A N/A N/A
52 54146 N/A N/A N/A N/A
53 33311 N/A N/A N/A N/A
54 10114 N/A N/A N/A N/A
55 10422 N/A N/A N/A N/A
56 5912 N/A N/A N/A N/A
57 31 N/A N/A N/A N/A
58 36836 N/A N/A N/A N/A
59 0 N/A N/A N/A N/A
60 0 N/A N/A N/A N/A
61 ERROR: Channel 61 Not Available
62 ERROR: Channel 62 Not Available
63 ERROR: Channel 63 Not Available
64 ERROR: Channel 64 Not Available
65 ERROR: Channel 65 Not Available
66 ERROR: Channel 66 Not Available
67 ERROR: Channel 67 Not Available
68 ERROR: Channel 68 Not Available
69 ERROR: Channel 69 Not Available
70 ERROR: Channel 70 Not Available
71 ERROR: Channel 71 Not Available
72 ERROR: Channel 72 Not Available
73 ERROR: Channel 73 Not Available
74 ERROR: Channel 74 Not Available
75 ERROR: Channel 75 Not Available
76 ERROR: Channel 76 Not Available
77 ERROR: Channel 77 Not Available
78 ERROR: Channel 78 Not Available
79 ERROR: Channel 79 Not Available
80 ERROR: Channel 80 Not Available
81 ERROR: Channel 81 Not Available
82 ERROR: Channel 82 Not Available
83 ERROR: Channel 83 Not Available
84 ERROR: Channel 84 Not Available
85 ERROR: Channel 85 Not Available
86 ERROR: Channel 86 Not Available
87 ERROR: Channel 87 Not Available
88 ERROR: Channel 88 Not Available
89 ERROR: Channel 89 Not Available
90 ERROR: Channel 90 Not Available
91 ERROR: Channel 91 Not Available
92 ERROR: Channel 92 Not Available
93 ERROR: Channel 93 Not Available
94 ERROR: Channel 94 Not Available
95 ERROR: Channel 95 Not Available
96 ERROR: Channel 96 Not Available
97 ERROR: Channel 97 Not Available
98 ERROR: Security access required
99 ERROR: Channel 99 Not Available
And repeating up to channel 255
paradyne is offline
