VAG-COM problem with S5 - 'No response from controller' - Audi A5 Forum & Audi S5 Forum
post #1 of 13 Old 2nd May 2010, 04:21 AM Thread Starter
Fuzzb's Avatar
Howdy. I just tried to hook up my S5 Cab to VAG-COM using a genuine cable, and after following a quick start guide posted on here, I keep getting 'No response from controller' errors when I try to do the following:
On main screen click Select button under 'Select Control Module'
Select 'Electronics 1' tab
Click '07-Control Head' button
Error message pops up.
I've set up and tested the cable in the Program Options window, and it all tests out OK. Since the cable is connected via USB, I've selected the USB radio button in the Select Port panel.
Has anyone run into this problem before? I've Google'd this error and tried the workarounds that people have posted to no avail. I've also followed the FAQ section on the Ross-Tech website, but that didn't help either.
I'm running Windows 7 x64 on a MacBook Pro (running in battery mode).
Any help gratefully received
S5 Cabriolet [ordered 11 Feb 2010, built week 15 (w/c April 12th), collected 1st May]
Sprint Blue, Black / Black, 19" 5 Arm Double-Spoke Alloy Wheels, Technology Pack, Parking System Advanced, Bang & Olufsen Sound System, Bluetooth Interface, Convenience Pack, Heated Front Seats, Advanced Key, Audi Drive Select, Quattro Sports Differential, Damping Control, Hill-Hold Assist, Tyre Pressure Monitor
Fuzzb is offline
post #2 of 13 Old 2nd May 2010, 05:39 AM
fred44nl's Avatar
hi,
did you install the special USB-driver ??
does the USB-device show up in the hardware list ??
A5 SB 2.0 TFSI 155kW quattro Pro-Line S-tron. (16 febr. 2010 - .....)
A3 HB 2.0 FSI 110kW Pro-Line - 8P (26 jan. 2007 - 16 febr. 2010)
 MacBook Air 4.2 - i7 - 256 GB SSD (aug. 2011) - Sierra
Original Ross-Tech cable with Vag-Com/VCDS - 16.8.3
fred44nl is online now
post #3 of 13 Old 2nd May 2010, 07:30 AM
What mod were you trying to make?
NOLA_S5 is offline
post #4 of 13 Old 2nd May 2010, 08:26 AM Thread Starter
Fuzzb's Avatar
Originally Posted by fred44nl View Post
hi,
Yep I installed the driver and it does show up in device manager. Running the hardware test within the VCDS application also works fine.
Fuzzb is offline
post #5 of 13 Old 2nd May 2010, 08:33 AM Thread Starter
Fuzzb's Avatar
I was trying to enable the hidden menu in the MMI.
Fuzzb is offline
post #6 of 13 Old 2nd May 2010, 08:48 AM
Might seem silly but do you have the ignition on? You can perform a lot of functions with it off.
2010 S5 Prestige Phantom Black/Black | Drive Select | Driver Assist
Replaced...2010 A5 2.0T MT6
Moved on...2006 A6 Silver
Gone...1992 CS 100 Quattro Wagon
kdstrunk is offline
post #7 of 13 Old 2nd May 2010, 08:56 AM
Use this link http://www.audienthusiasts.com/VagCom.html
I have a 2010 and just did mine Friday. The MMI 2G units use the 07 control head selection. 3G is accessed diferently.
The tricky part is accessing the hiden menu. Its a little tricky pressing and holding the car and setup button at the same time. It took me a few tries before I got in.
NOLA_S5 is offline
post #8 of 13 Old 2nd May 2010, 09:01 AM
fred44nl's Avatar
you have to press "Setup" first, immediately followed by pressing "Car"
now you hold them down together.
post #9 of 13 Old 3rd May 2010, 02:55 AM
Quoted: 34 Post(s)
Your car has no 07-control head, that's why you can't reach it.
Try 5F, that is what you're looking for.
2011-??: S5 4.2 FSI manual, auxilliary heater, keyless, memory seats, navi, rear cam, etc.,
upgrades: chiptuning, Vmax off, Milltek resonated exhaust, VCDS mods (ADS, TPMS, highway lights), ADS switch, RS5 pedals, Bluetooth, LED rear lights, OZ Racing Superturismo Le Mans wheels (graphite grey).
2007-2011: A5 3.0TDI Quattro Sportmotor edition, KW V2, Caractere, OZ Ultraleggera HLT 19'', chiptuning 220kW, K&N, Milltek, LED, RS5 pedals, lots of VCDS mods
C99 is online now
post #10 of 13 Old 3rd May 2010, 03:46 AM Thread Starter
Fuzzb's Avatar
Thanks for the replies. in the end it turned out that I was being an idiot and trying to access a control module that wasn't present as C99 suggested.
I've now got everything working and have applied the codings that I wanted.
Fuzzb is offline
post #11 of 13 Old 28th August 2012, 07:15 AM
I've got the same problem.
I can plug the cable to laptop ok. It gives me the:
Port status:OK
Interface:Found!
Type:Serial Pass-Through
Opto/Iso:No
RossTech Design:No
I tried different com ports different baudrates. not sure whats happening.
Still says no response from controller.
Using 409.1 with a cable from ebay. Running on windows 7
surfer007 is offline
post #12 of 13 Old 28th August 2012, 07:56 AM
fred44nl's Avatar
which means you are running an illegal alibaba cable
post #13 of 13 Old 3rd October 2012, 01:41 AM
it won't work?
Do I need another one?
Anyone recommend anyplace, within Toronto would be better.
There is mention that there might a simcard slot inside the faceplate. I have the two SD Card faceplate.
