41 - 60 of 73 Posts
Discussion starter · #41 ·
Everything works like a charm..:)
Turns out I have not yet been out of the city yet...until this morning.
Hence, the assistant has not turned on the high beam until this morning.
The High-beam assistant is working just fine...:)
So I can confirm that the only programming needed for the high-beam assistant to work is to tick the option of high-beam assistant in 09 central electrics.
Mattias
Mattias
Cool,
So can you do a roundup of what was involved. The part numbers that are now in the car just to clarify in case I confuse the various changes you have made. Any wiring or revised looms required?
Vag com coding seems ok and I assume a trip to dealer for svm code for new can gateway
Its not that you need it. I have done a lot of mods on my car that are, to be honest completely unnecessary. The read light LED retrofit was a complete waste of money. The folding mirrors as well. But that is not why you do it, now is it? I do it because it is a challenge to figure out how it is done, and it is fun. And it makes my car look better.
Now back to the issue at hand I have managed to install the Can-Gateway now (or my dealer eventually did). Now I have the symbol in the DIS with highbeam assistant on, but I think that I need something more changed in the programming. turning on the highbeam assistant in the central electrics module (with VCDS) does not seem to be enough? Anybody can help with that?
Mattias
I know its out of topic, but i was wondering what was the code you needed to change for the OEM LED reading light retrofit.
I did mine on the audi a6 2012, and when i open the door the lights don't go on. And the switch (door open) doesn't work. Any tips ?
Thank you
retrodit to mmi 3G
hello ,
i have A4 2010 , i have already buy 8t0 907 468 AD , but the dealer tell me that i can not do a retrofit to mmi 3G because i m coding a control unit that is not specified for that chassis number?
i don't know if it's the correct answer or not , if 8t0 907 468 AE , can work or not ,
I have a big problem , i have no sound , and i m in the safe mode , with AD .
please help me
thank you
I dont know about all dealers, but the one I go to, do what I ask them to do.
They know I know the car well, and understand that I need them to do things that I can not do on my own. And it is a way for them to get money.
Many if not all jobs at the Audi dealer (as I understand it) have "routine numbers". This number is basically, a number so that the dealer can look up what needs to be done to do something. Although I dont know the actual number, I do know that coding a control unit has a routine number, hence Audi has provided the dealers with instruction on how to do it. Therefore, I think all dealers should be able to do it...?
Mattias
hello ,
please help me
thank you
you have to remove the component protection, and coding the AD module
Ok. Im going to have a look at all the various components related to headlight assistant in my car tomorrow to see what versions I currently have. I really want to do this mod but if everything needs changing, it might be too much. Then again if only the module needs changing I will go onto it.
Fantastic mod for the type of driving I do, continually dipping beams.
Snap,
Sorry no, you need to physically check them I think unless under 09 central electrics this will give the switch info?
Also post #40 bluetone said he isntalled 'D' version of can gateway and it worked?
rgds
JB
Mick, just chedked Etka and the part code for the switch ties up with 09 central electrics 3rd part down so you can check your switch in VCDS yes, mine is rev G
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0392
Revision: 10029001 Serial number: 00000000597432
Coding: 060010910010AF211705000000001D0D419D03C802000141000000
Shop #: WSC 00561 210 84735
VCID: 3C7C287406ED
Part No SW: 8T2 955 119 B HW: 8J2 955 119
Component: WWS 061107 H11 0040
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0002
Coding: 02532C
Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
No fault code found.
Mine is 8T0 907 468 D.
They were referring to 8r0 907 468 D. I should have made that clear. Mine is the original module from 08. They said the 'r' module is a 2012 version good for the full PR code list.
Thanks for all that info above.
Latest one is Rev 'M'
Looking at my headlight switch, Ive got version G and etka tells me thats good for 8N7 so hopefully no change needed there.
Will have to check the mirror part number.
Also looking out for a late model Can gateway thats good for 8N7 on Ebay, there are the following available gateway modules:
8T0 907 468 AB
8T0 907 468 M Not suitable acording to etka
8T0 907 468 R
8T0 907 468 H Not suitable accrding to etka
8T0 907 468 T
My etka is old so it doesnt refer to the versions AB, R or T.
Can anyone check whether those are good for 8N7 and are 'CAN' not 'MOST'.
8T0 907 468 AB
8T0 907 468 R
8T0 907 468 T
AB and R are CAN (but not for 8N7), T is MOST. S, AC and AG are good for 8N7
Read through this and a little confused - so simple question
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Will the headlight assist work with this CAN gateway by adding the mirror and coding the 09 central electrics?
Actually Dave it's a little hard to say. In my opinion, no you don't have the right CAN gateway for headlight assist and lane assist.
Complication is that ETKA for MY2010 shows AE (up to Oct '11) or AJ (Oct '11 on) revisions for headlight and lane assist (8N7)... but they list AE and AJ multiple times. 3 times each, in fact... with different PR codes for each. 2 versions of each are 8N6, without, and 1 version of each is 8N7. Very bizarre.
The long-short of it is that you probably need a new one anyway. If you've got dynamic steering, it would be an opportunity to add lane change assist - let me know if you'd like me to estimate the cost involved.
Thinks it may be a little too much work and effort for little benefit
Discussion starter · #56 ·
Hi all,
Been a while since I wrote on this forum.
Nowadays I have a A5 with MOST (2G MMI high).
The old one only had the CAN based Audi concert stereo (no navi).
Now I am trying to do the same retrofit of the High beam assistant on my new car.
Problem is, I no longer have access to the electronic circuit diagrams of ETKA.
I only have the one posted in this thread, but I believe that it is only valid for cars with only "CAN".
Anybody could provide me with the same diagrams but for cars with MOST?
Regards,
Mattias
I would like to retrofit the high beam assistant, i have cruise control, rain and light sensors, mmi 2G, side assist on a A5 coupé.
What do i need? Only the HBA mirror and codding or i have to change the CAN?
Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 AD HW: 8K0 907 064 AD
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Another question, is it possible to retrofit the lane assist wihtout ACC?
Thks
Discussion starter · #58 ·
Thks
Hi have basically the same car as you 2g navi, cruise control, rain and light sensors (no side assist though).
I have installed the mirror to fit the high beam assistant, but I think what i need is a new Can gateway.
From the factory, I have 8T0 907 468 L installed (just like you).
If I am correct, you (we both) need "8T0 907 468 Q" version.
To get this working.
I have bought this can gateway but I have not tried it yet, so I cant make any promises that it will work.
But if I have read ETKA correctly, that is what we need.
REgards,
Mattias
REgards,
Mattias
Hi Mattias,
Thks for your help, have you codded your Can 8T0 907 468 L in Central Electrics option for High beam assist? I have a friend with a Q5 with the same CAN as yours and he has High beam assist from factory. I don´t have the HBA mirror so i don´t know if it works or not.
Do i nedd to change the light switch also or the thing i nedd is the mirror and
maybe a new CAN?
Thks
Hi Mattias,
maybe a new CAN?
Thks
Has anyone tried this?
41 - 60 of 73 Posts
