Need some advices on the wheels spacers. - Audi A5 Forum & Audi S5 Forum
post #1 of 8 Old 20th February 2017, 10:04 PM Thread Starter
I have purchased a set of 19x9.5J with ET35 for my facelift A5 coupe and I am planning to go for H&R Sport spring with 35mm drop (my car has an non-sline suspension). I am planning to run 2553519 tyre.
However, I would like to buy the spacers and install all the things together. Should I go for H&R 15/20 or 20/25 or 20 all around. I know that DRA system would be better without the need of longer wheel bolts of the DR. I dont want to make the rear wheel to trucked in the arch. I want to get the flush look
Thanks so much!
Jasonfok908 is offline
post #2 of 8 Old 17th March 2017, 02:33 AM
Hi, this might be a little too late but here goes. My car is pre-facelift though. (2010 A5 Coupe, S-line)
I have 19x9J with ET33, H&R sport springs and 20mm F | 25mm R spacers. Tyres are 255/35R19. My wheels just clear the fenders and I have no rubbing with this setup.
I used an offset calculator and with 20mm F | 25mm R, your wheels will stick out 4mm over and above my setup. So my advice will be to choose the 15mm F and 20mm R spacers
Name:	2017 rnd 1 - 002.jpg
Tjaart is offline
post #3 of 8 Old 18th March 2017, 02:42 PM
Quoted: 24 Post(s)
hi Tjaart
i have a a5 cabriolet with 9x19 et33 i was looking at spacers but was told id need lower it or it will make the gap look bigger just with the spacers.
i nearly brought 15/20 but you mention you have 20/25
im thinking dr system is better/safer than dra ? ive heard off a few on different forum so would appreciate your opinions, and also what system are you using??
also any pics of you car (side shot) to see how low it is and if the front has dropped more than the rear?
how much has it lowered by and whats the ride like compared to the s-line set up mines a TDI by the way.....is yours?
vw754 is offline
post #4 of 8 Old 19th March 2017, 08:41 AM
I don't have enough posts to embed pictures, therefore I will split my response into multiple posts not to confuse the pictures.
This is a matter of opinion I think. To me the spacers improve the overall look. With the A5, the wheels are deep inside the fenders. So over and above the gap looking from the side, you have the inward wheel gap looking at a 45 degree angle from the front/rear as well. After adding spacers, you only have the gap looking from the side. So in my opinion the overall look is better. Here are some pics to help you decide. (rims are 19x9.5J ET35)
Name:	Before, gap analysis.jpg
ID:	139042   Click image for larger version
Tjaart is offline
post #5 of 8 Old 19th March 2017, 08:42 AM
Personally I think DR is fine for 15mm and less. 20mm and up, rather go DRA (2 sets of bolts). I want to do track days with the spacers if I need to and with the DRA spacers, to me, there are more forgiveness of things that can go wrong. Running 20/25mm spacers with very long bolts under high stress, I think rather not for my requirements. And, I had mine made with 5x112 and 5x120 PCD. Now they are adapters as well so I can fit a wider selection of wheel designs.
Tjaart is offline
post #6 of 8 Old 19th March 2017, 08:44 AM
My car is the 2010 Audi A5 Coupe 3.0TDI S-tronic, S-line, but sport suspension (20mm drop from standard suspension, more or less). I have the H&R Sport springs, code 29059-2. (35mm drop from standard suspension, more or less)
See pictures.
The front is slightly lower than the rear. At this point it has not bothered me enough to do something about it.
As mentioned, I had the sport suspension. So I will compare the ride comfort between that and the H&R sport springs. To me the ride is not too much more firm after the lowering springs. Because of their progressive design, for small road imperfections they are very close to before. Big imperfections they are hard and they need to be not to bottom out. So for most of the time spent in the car the ride is about the same. I have recently changed my tyres from 255/35R19 to 255/40R19 and comfort is good again for normal road conditions.
ID:	139066   Click image for larger version
Tjaart is offline
post #7 of 8 Old 19th March 2017, 04:19 PM
Quoted: 24 Post(s)
previously you said you had 9x19 et33
now your saying you have 9.5 x 19 et 35 ?
can you explain?
vw754 is offline
post #8 of 8 Old 20th March 2017, 01:28 AM
can you explain?
Sorry for the confusion. The previous advice for the 19x9J ET33 stands. That is the stock S-line rims. The only pictures I had to show the gaps for before and after the spacers was with 19x9.5J ET35 rims I had fitted to the car at that time. I mentioned their size because they sit closer to the fender, thus the stock S-line rims will have a bigger inward gap.
I sold those 19x9.5J rims and bought the lowering springs with the money. So all my spacer and lowering advice is based on the 19x9J rims.
Tjaart is offline
