Lowering the car!! Need some advice please! - Audi A5 Forum & Audi S5 Forum
post #1 of 15 Old 15th February 2017, 05:01 PM Thread Starter
I have recently bought a 19x9.5J ET35 wheels and planning to add a 15mm F and 15or20mm R spacers. However, I would like to change the suspension spring at the same time to save some time.
I am after KW spring or H H&R Sport Springs. But I am not sure which mm do I need . I want to get a flush look without any rubbing and not lowering too much with about 1 - 1.5 finger gap left between the wheel and fender.
My car is an A5 2.0 TDI with std suspension. Thanks so much!
Jasonfok908 is offline
post #2 of 15 Old 15th February 2017, 11:11 PM
hi mate
Iam running 20x9.5j et35
I have 25mm spacers at the back and 20mm spacers at the front and lowered all round on H&R springs that give it a 30mm drop with no rubbing at all ( I have an s -line) and about a 1 figer gap.
when you say standard suspension I assume yours is not an s-line or doesn't have sport suspension (lower than standard suspension)
your spacers will be fine with the wheels you have and shouldn’t experience any rubbing
you should lower about 35 mm to get the flush look you are after with a finger gap between arch and tyre as required
thanks
D2JML is offline
post #3 of 15 Old 16th February 2017, 07:47 AM Thread Starter
hi mate
your spacers will be fine with the wheels you have and shouldn?t experience any rubbing
thanks
Thanks so much mate! You basically answer all the questions that I had! U were correct, I am having the non s-line suspension. But I just wanna ask should I go for the h&r 35mm sport spring or 30mm? Thanks!!!
post #4 of 15 Old 16th February 2017, 11:32 PM
No worries Pal, go for the 35 seem as you have non s line suspension
look forward to the pics
D2JML is offline
post #5 of 15 Old 18th February 2017, 09:23 PM Thread Starter
Thanks mate, but have you got any pict of your car. I am still not sure if I should go for 35mm. I don't want to get it too low, and I just wanna a reasonable lower than stock look. And I also have to travel up and down hill, speed bump and car park normally. Thanks!
post #6 of 15 Old 18th February 2017, 11:15 PM
ColoA5's Avatar
This is a 2011 with 20-25 Hr spacer and HR sport springs....
H&R 20mm Front 25mm rear DRA spacers,
H&R OE Sport Springs
K&N Air filter, Rear
Audi 4 Ring Entry Lights,
Ultra Racing strut brace,
ColoA5 is offline
post #7 of 15 Old 18th February 2017, 11:55 PM Thread Starter
Thanks mate, are all the sport springs with 1.3" drop (35mm) and have you got the S-line suspension or non-sline one? Thanks
post #8 of 15 Old 19th February 2017, 08:09 AM
ColoA5's Avatar
Depicted is a non s-line 2.0 (non tdi). Hope this helps.
ColoA5 is offline
post #9 of 15 Old 21st February 2017, 02:27 PM Thread Starter
Is this Sport spring or OE sport Spring? Coz i saw your pervious post said that u had OE sport
post #10 of 15 Old 21st February 2017, 11:25 PM
if you have got instagram check out my profile @D2JML
plenty of pics on their to see my ride height
D2JML is offline
post #11 of 15 Old 22nd February 2017, 05:48 AM Thread Starter
Your car look sick!!! Just wanna ask where did you get the red seat belt done?
Moreover? For the lowering spring, I guess your sline suspension with h&r sport spring will be lower than mine of the standard suspension with h&r spring. Thanks!
post #12 of 15 Old 22nd February 2017, 05:59 AM
Quoted: 50 Post(s)
AFAIK, according to H&R they advise the amount of lowering from their springs is given in mm from a baseline model. The sport springs from H&R as I understand it, will lower the A5 by 35mm from the standard baseline car. If the A5 further have S-line or S-line sport springs on it will not have an effect on the base amount of lowering, but relatively, as I think the S-line and sport are 10 and 20mm respectively from the standard? you'll get a car that then would be 25 or 15mm lower on H&R sport springs.
As I understand it, like for like the car would achieve the same height over ground if you both go for the same lowering springs. I forgot the difference between H&R and H&R sport but I think it's 10mm?
Mr.wreckless is offline
post #13 of 15 Old 22nd February 2017, 06:14 AM Thread Starter
Thanks mate, so I guess I will be very safe to run 35mm drop as my car is an basemodel?
post #14 of 15 Old 22nd February 2017, 08:52 AM
A5JXU08's Avatar
Quoted: 32 Post(s)
Mine on -35mm H&R,s with 15mmF and 20mmR spacers.
Since these pics were taken (2 days after fitting) the car has dropped some more, probably another 5mm all round
Name:	Just about done 17-4-16 #3.jpg
ID:	136794   Click image for larger version
Name:	Just about done 17-4-16 #7.jpg
2008 2.0 ltr TFSi Sport
ECS intake pipe, Pipercross filter, R8 red tops, 15mm (F) & 20mm (R) spacers, -35mm Springs, Eccentric, Poly, upper control arm bushes, Debadged and Dechromed, OEM Audi body kit (lip spoiler, side skirts, diffuser and bumper spoilers, boot lip spoiler.
Have the parts to do:-
Full RS5 Piano black trim, RS5 pedal set and foot rest, ECS oil catch can kit.
A5JXU08 is online now
post #15 of 15 Old 22nd February 2017, 01:01 PM
Quoted: 50 Post(s)
I have -35mm HR on mine and with reference to your picture mine is roughly the same at the rear and much lower at the front. The front wheels start to disappear into the arch on mine.
