B&O Subwoofer Problem After MMI Update - Audi A5 Forum & Audi S5 Forum
  • 1 Post By Baas J.
post #1 of 24 Old 9th August 2015, 10:24 AM Thread Starter
Hey guys!
I am having a bit of a problem with my A5 2008's Bang & Olufsen Subwoofer after I updated my MMI 2G HI to the latest version - 5170 / 5570. I noticed that after updating the firmware, my subwoofer stopped working completely - I am not getting any bass out of it whatsoever. The peculiar things about that are two:
1. I was aware of the "lack of bass" issue that is affecting the A5s fitted with B&O and the 5570 update. However, the funny thing is that I noticed the lack of bass after updating from 3250 to 5170 (TUN v. 620). Before that, on the 3250, everything was working as intended.
2. Updating to 5570 (TUN v. 630) did not resolve the issue. Neither did downgrading to TUN v. 620 (naturally).
I am at a loss here thinking that the only way to get my subwoofer up and running again would be to downgrade the TUN to the version included in the 3250 firmware (which I have absolutely no idea how to obtain the CDs / images for).
What do you guys think about it? Has this ever happened to any of you?
I will really appreciate some help here
Cheers!
Loyal2DaGame is offline
post #2 of 24 Old 17th November 2015, 01:13 PM Thread Starter
Come on guys Has no one encountered this issue before?
post #3 of 24 Old 18th November 2015, 04:02 AM Thread Starter
Attaching a VCDS Log:
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 C
Component: DSP Prem H11 0400
Revision: 00H11003 Serial number: 34812000284800
Coding: 030101
Shop #: WSC 12336 024 394758
VCID: 3F81C0FF3E7DBCFB3A9-806A
3 Faults Found:
00419 - Left Front DSP Midrange Speaker (R103)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 109
Mileage: 192584 km
Time Indication: 0
Date: 2015.10.03
Time: 23:04:09
Freeze Frame:
Voltage: 12.40 V
Temperature: 2.0°C
Temperature: 29.0°C
Bin. Bits: 00000100
02247 - Subwoofer (R148/R157)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 109
Mileage: 192584 km
Time Indication: 0
Date: 2015.10.03
Time: 23:04:09
Freeze Frame:
Voltage: 12.40 V
Temperature: 2.0°C
Temperature: 29.0°C
Bin. Bits: 00000100
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 109
Mileage: 192584 km
Time Indication: 0
Date: 2015.10.03
Time: 23:04:11
Freeze Frame:
Voltage: 12.40 V
Temperature: 3.0°C
Temperature: 30.0°C
Bin. Bits: 00000100
Bin. Bits: 00000010
Bin. Bits: 00000000
post #4 of 24 Old 9th December 2015, 04:01 AM Thread Starter
*Bump*
post #5 of 24 Old 9th December 2015, 04:10 AM
fred44nl's Avatar
011 - Open Circuit
speaks for itself, I would say.
same
this is a result from the updates and is not harmful
A5 SB 2.0 TFSI 155kW quattro Pro-Line S-tron. (16 febr. 2010 - .....)
A3 HB 2.0 FSI 110kW Pro-Line - 8P (26 jan. 2007 - 16 febr. 2010)
 MacBook Air 4.2 - i7 - 256 GB SSD (aug. 2011) - Sierra
Original Ross-Tech cable with Vag-Com/VCDS - 16.8.3
fred44nl is online now
post #6 of 24 Old 9th December 2015, 07:26 AM
Quoted: 118 Post(s)
I would recommend reverting the firmware version of your MMI back to 3250 to see if you still get the same faults. This is to verify whether it is software that is giving you these faults. If after reverting back to version 3250 you get the same fault codes then there may be an actual electrical fault (whether bad speaker, wiring, termination, etc.) involved.
plat27265 is offline
post #7 of 24 Old 10th December 2015, 11:34 AM
Quoted: 52 Post(s)
I have the same.....dont know what is causing it, subwoofer does play though...
Baas J. is online now
post #8 of 24 Old 14th December 2015, 01:32 AM Thread Starter
Hey everyone, thanks so much for replying!
The subwoofer error was there even before I updated the MMI and as Baas J. pointed out, the subwoofer was working as intended. I'm guessing the main problem is with the 03175 - Invalid Data Set error, which appeared only after I went through with the update.
Does anyone have any idea how I can fix this one in particular? As plat27265 suggested, it would probably be best if I downgrade to 3250, but then again I couldn't find the discs for it on the Internet. Does anyone have it by any chance?
post #9 of 24 Old 14th December 2015, 01:35 AM
fred44nl's Avatar
as I said earlier:
there is a way to fix it, and this is in the beginning of this thread.
post #10 of 24 Old 15th December 2015, 01:27 AM Thread Starter
Originally Posted by fred44nl View Post
as I said earlier:
Well it is harmful in the sense that it's causing the problem I am experiencing. I seem to be missing something, how do I go about fixing it? By downgrading the MMI software?
post #11 of 24 Old 18th December 2015, 11:55 AM
Quoted: 52 Post(s)
I fixed the problem by entering different coding for the amplifier. Now I have no errors anymore.
Coding below:
Address 47: Sound System (J525) Labels: None
Part No SW: 8T0 035 223 AP HW: 8T0 035 223 AJ
Component: DSP Prem H19 0290
Revision: 00019001 Serial number: 34835000625102
Coding: 0203010302
Shop #: WSC 06335 123 12345
VCID: 7CF7127BFF1EBCFEC8B-8029
No fault code found.
plat27265 likes this.
post #12 of 24 Old 18th December 2015, 12:27 PM
Quoted: 118 Post(s)
Coding below:
Coding: 0203010302
Well, I am glad you were able to resolve it! Congrats!
post #13 of 24 Old 21st December 2015, 02:14 AM Thread Starter
Coding below:
Coding: 0203010302
Did the subwoofer start working again after you changed the coding?
*EDIT* Oh, never mind me, yours was working even with that error being detected.
post #14 of 24 Old 30th December 2015, 07:27 AM
Quoted: 52 Post(s)
Damn, I noticed I have the: 02247 - Subwoofer (R148/R157) 012 - Electrical Fault in Circuit back again.... arghhh
Contact me for rear LED adapters and other wire harnasses for retrofitting.
post #15 of 24 Old 30th December 2015, 08:07 AM Thread Starter
At least your subwoofer is working as intended, unlike mine That's utterly annoying though...
post #16 of 24 Old 6th January 2016, 12:25 PM
Quoted: 52 Post(s)
I ordered a new subwoofer..... I think the fault is internally...will keep u posted.
post #17 of 24 Old 8th January 2016, 02:22 AM Thread Starter
Great! Thanks!
post #18 of 24 Old 10th January 2016, 04:29 AM
Hi Loyal2DaGame
I also struggle with a similar "Invalid Data Set" problem on my new B&O amp (old was water damaged). My local Audi dealer say they can't solve it.
One thing I find interesting is when reading out Measuring Block 32 and 33 from amp, it looks like it have never been programmed with sound settings as I have "2006:08:07 Data Set Creation Date" and "0x0000 Successful Write Attempts".
Can any one confirm this config is ok or are there any updated sound setting available to 8T0035223T?
MMI have v5570 and I experiencing that volume is randomly changing while driving and bass is low (subwoofer is working).
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34821000212xxx
Coding: 020101
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 59597 km
Time Indication: 0
Date: 2014.07.29
Time: 14:49:28
Freeze Frame:
Voltage: 11.80 V
Temperature: 45.0°C
Temperature: 48.0°C
Bin. Bits: 00000100
Bin. Bits: 00000010
Bin. Bits: 00000000
Address 47: Sound System (8T0 035 223 T)
16:46:30 Group 032: Control Module Data Set I
00010000 Supported Sound Settings
11 Supported Sound Settings
0x0500 Data Set Version
16:46:36 Group 033: Control Module Data Set II
0x0000 Over-All Write Attempts
N/A
N/A
08 Audi S5 Man, Phantom Black
AutoPC is offline
post #19 of 24 Old 10th January 2016, 05:45 AM Thread Starter
Have you enabled the GALA feature? If so, this can be what's causing your sound volume to increase / decrease all the time. I had mine disabled as I found it to be more annoying than helpful
post #20 of 24 Old 17th January 2016, 10:05 AM
Quoted: 52 Post(s)
Yes Gala is annoying indeed.
post #21 of 24 Old 27th April 2016, 11:23 AM
Hi,I have an Audi A5 2008 with b+o system and it has suddenly gone all tinny,took it down to specialist and he has got something working eg volume is back and their is a slight bass but no where near the quality it was,frustrated is an understatement....he said he can't find any faults but I know for sure something is wrong...any advice would be much appreciated.cheers
Swelsh2709 is offline
post #22 of 24 Old 2nd May 2016, 01:42 AM Thread Starter
Do you have VCDS? If so, scan for problems and see if anything will come-up.
post #23 of 24 Old 4th May 2016, 05:21 AM
@Baas J problem solved?
Bashonselaar is offline
post #24 of 24 Old 30th September 2016, 10:33 PM
Quoted: 38 Post(s)
B&O loss of bass: Loss of Bass in B&O after 5570 upgrade
2011-??: S5 4.2 FSI manual, auxilliary heater, keyless, memory seats, navi, rear cam, etc.,
upgrades: chiptuning, Vmax off, Milltek resonated exhaust, VCDS mods (ADS, TPMS, highway lights), ADS switch, RS5 pedals, Bluetooth, LED rear lights, OZ Racing Superturismo Le Mans wheels (graphite grey).
2007-2011: A5 3.0TDI Quattro Sportmotor edition, KW V2, Caractere, OZ Ultraleggera HLT 19'', chiptuning 220kW, K&N, Milltek, LED, RS5 pedals, lots of VCDS mods
