Why will my SD card not work?? - Audi A5 Forum & Audi S5 Forum
post #1 of 16 Old 11th November 2009, 10:04 PM Thread Starter
I have now purchased 3 different SD cards and it is really starting to piss me off. I have purchased a 2GB and two different 1GB and I still get the same "unreadable" message when I insert the card.
Has anyone has a similar experience?
Kill_Bill_Vol.2 is offline
post #2 of 16 Old 11th November 2009, 10:11 PM
BmthMike's Avatar
I have 2 8GB cards in mine and works fine, what model year is your car?
A5 3.0TDI S-Line Cabriolet-Phantom Black-B&O-Interior Light Pack-Tech Pack High-Mobile Phone Prep Low-19" 5 Seg spoke-Heated seats-Neck level heating-Piano black inlays-Milano leather-Tyre pressure Monitor-ordered 02/09/2009 delivered 28/10/2009
BmthMike is offline
post #3 of 16 Old 11th November 2009, 10:24 PM Thread Starter
I have a 2010 A5
post #4 of 16 Old 11th November 2009, 11:33 PM
Ageing Biker's Avatar
Sounds wrong to me. I hope this doesn't happen to me. I have a 4GB SDHC card that I have already loaded 2GB onto in anticipation of the car's arrival. If it persists, I would go back to your dealer.
Gone(company car) Audi A5 2.0TFSi 180 2010 S-Line Special Edition (19" Y Alloys, B&O, Phone prep Low) Ibis White, AMI, Leather/Alcantara with Silver Stitching, Interior Lighting Pack, Parking plus, Electric Front Seats. Built 22nd October, landed in UK 12/11, delivered to dealer 13/11, arrived 25th November!!.
Now. VW Tiguan SE 2WD 2.0TDi. Mirror pack and touch-screen DAB radio/6 CD autochanger with Dynaudio pack, in (of course!) Candy White.
Ageing Biker is offline
post #5 of 16 Old 12th November 2009, 02:11 AM
Probably a really silly question, but what format are you using for the music files?
If the answer is I suspect it will be, try formatting the SD cards first, then downloading data.
A5 Cab Ibis White 3.0TDi Quattro S-Line, S-Tronic, Tech Pack (3G MMI Sat Nav, AMI, Xenons & DRLs) 19" '5 Spoke' RS6 Style Alloys, Heated Front Seats, Interior Light Pack, Hill Hold, Parking Plus, B&O, Auto Dimming Interior Mirror & Auto Folding / Dimming Exterior Mirrors, Mobile Low, Cruise, Tyre Pressure Monitor, Acoustic Roof, Rear LEDs MODS: Voice Control, Door Lock Confirmation Beep, Needle Sweep, DVD in Motion, Ambient Lighting, Rear LEDs as DRLs
Mark is offline
post #6 of 16 Old 12th November 2009, 03:12 AM
rnlabas's Avatar
Unless things have very recently changed - and Audi themselves seem somewhat confused about this - their drivers do not always support SD cards and it seems to be brand picky - the best luck (read consistent) is to use non-HD cards - that usually means 4gb or less - sorry ...
- Roger
__________________________________________________ _____________
Quartz/Tuscan/Carbon/Black Optik - AWE Track Edition - Hartmann HS5-209 20s - AWE Pedals - STāSIS Challenge Suspension - eCodes F & R -
Alu-Kreuz - Brembo GT-R (Nickel Monobloc) Front : OEM RS5 Rear - TTS Supercharger -
rnlabas is offline
post #7 of 16 Old 12th November 2009, 03:19 AM
ChristopherPovey's Avatar
Quoted: 26 Post(s)
Might help. What brand are your two cards?
Chris.
Actual Fuel Consumption: 33.27 MPG (UK Gallon)(Premium Unleaded 95 RON)
Actual Fuel Consumption: 33.08 MPG (UK Gallon)(Super Unleaded 97+ RON)
Price per Mile: 0.18GBP (Premium Unleaded 95 RON)(May-2010 to Feb-2012)
Price per Mile: 0.18GBP (Super Unleaded 97+ RON)(Feb-2012 to - Feb 2016)
Oil Consumption:1292.99 Km/Ltr
ChristopherPovey is offline
post #8 of 16 Old 12th November 2009, 07:03 AM
BmthMike's Avatar
I use scan disk SDHC cards and 320KBS Mp3 files, works fine, both 8 Gigs
BmthMike is offline
post #9 of 16 Old 12th November 2009, 07:11 AM
Do you have 3G MMI or do you have the Concert or Symphony radios?
The 3G MMI should read just about any SD card that is properly formatted (SD or SDHC up to 32GB), as long as it's at least Class 4.
I'm not sure of the exact specs for the other non-MMI radios but they should accept a 1GB or 2GB card. I would try repartitioning and reformatting as FAT32 (and re-copying your music) and see if it works. You should also make sure your music is in a recognized format such as MP3 or potentially .M4A.
2010 A5 2.0T Tip
Quartz Gray / Prestige / S-line / Driver Assist
Hartmann HS5-209 Wheels (19")
Scottacus is offline
post #10 of 16 Old 12th November 2009, 02:41 PM
DeMOROlized's Avatar
How did you format the cards? For best compatibility format the card as FAT16.
1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
2nd Ring: 2006
Moro Blue B7 A4 2.0TqMS
3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
4th Ring: TBD
DeMOROlized is offline
post #11 of 16 Old 16th November 2009, 09:47 PM
I just tried an 8gb, a 4gb, and a 2gb sd card. Only the 2gb card worked (other 2 said unreadable) and it's a really cheap one that is not hd. I have the B&O system and really would like to use bigger than a 2gb so gonna try the el cheapo brand (kingston) in 8gb.
OldlightsA5 is offline
post #12 of 16 Old 17th November 2009, 01:53 PM
Older units won't support SDHC. The 8GB one is definitely an SDHC and I suspect the 4GB one is SDHC as well.
2nd Ring: 2006
4th Ring: TBD
post #13 of 16 Old 18th November 2009, 08:16 AM
loc
Any 2GB *SD* and smaller should work, SDHC will not work in older A5s. Some, e.g. Transcend *SD* (not SDHC) 4GB cards work on older A5s. New 2010s should handle SDHC cards that allow larger sizes too.
My A5 retrofit links: A5 VAG COM codes list
A5 "real" MMI vs. radios explained
AMI parts/retrofit
Homelink retrofit
Voice control retrofit
Add oil dipstick
loc is offline
post #14 of 16 Old 18th November 2009, 08:18 AM
loc
See this thread:
http://www.a5oc.com/forums/showthrea...888/index.html
AMI parts/retrofit
Homelink retrofit
Add oil dipstick
loc is offline
post #15 of 16 Old 10th January 2014, 02:44 AM
audiandrew1010101
Guest
Posts: n/a
Quoted: Post(s)
Hope this helps
Just wanted to add, in case it helps anyone, that I couldn't get my Audi to read an SD card. I formatted in NTFS and various FAT formats and nothing worked. As a last resort, I put the 16 GB Kingston card into my digital camera and formatted it via the menu. The card was then readable in the Audi.
I've so far put 9 GB of music on the card and all of it plays.
The PC reports the card to be formatted as FAT32 which I had tried and failed with before. So the camera must have formatted it in a slightly different way to Windows and the other partition tools I used.
post #16 of 16 Old 13th May 2015, 03:31 AM
I have Audi A4 B8 (2008) with Audi Concert http://www.a5oc.com/forums/attachmen...4&d=1315482574
HW: H02
SW: 0210
It was reading SD cards with MP3 files/ WMA files and CDs with MP3 files just fine.
However, 10 days ago it suddenly stopped and it shows "UNREADABLE" when I select the SD or CD. It is still reading normal music CDs. I`ve tested with several CDs and SD cards (not SDHC). I`ve tried "Default settings" MMI reset from the "SETUP" console of the car - didn`t help. I`ve removed the car battery - no change.
Please advise what else can I try.
rednull is offline
