A5 Brake Rotor size up - Audi A5 Forum & Audi S5 Forum
 2Likes
  • 1 Post By labombadiesel
  • 1 Post By Tomcat-R
post #1 of 17 Old 23rd July 2011, 01:23 PM Thread Starter
I wonder if it is possible to upgrade A5 Brake rotor to S5's rotor or not.
S5's rotor is a little bit bigger in diameter and heavier in Weight.
If possible, do I have to change Brake Pad and Caliper too?
Thank you,
James.
Here are some data:
A5's Front size
Outer Dia. 320.0mm
Height. 52.0mm
Nom Thick 30.0mm
Min Thick 28.0mm
Hub Size 68.0mm
Bolt Size 15.3mm
Bolt Circle 5x112.0mm
Weight 21.7 lbs.
S5's Front size
Outer Dia. 340.0mm
Height. 51.9mm
Nom Thick 30.0mm
Min Thick 28.0mm
Hub Size 68.0mm
Bolt Size 15.2mm
Weight 23.65 lbs.
A5's Rear size
Outer Dia. 300.0mm
Height. 36.0mm
Nom Thick 12.0mm
Min Thick 10.0mm
Hub Size 68.0mm
Bolt Size 15.3mm
Weight 12.2 lbs.
S5's Rear size
Outer Dia. 330.0mm
Height. 36.1mm
Nom Thick 22.0mm
Min Thick 20.0mm
Hub Size 68.0mm
Bolt Size 15.2mm
Weight 17.1 lbs.
Jkim15 is offline
post #2 of 17 Old 24th July 2011, 01:28 AM
Full Metal Jackass's Avatar
Originally Posted by Jkim15 View Post
Thank you,
James.
Here are some data:
A5's Front size
Outer Dia. 320.0mm
Height. 52.0mm
Nom Thick 30.0mm
Min Thick 28.0mm
Hub Size 68.0mm
Bolt Size 15.3mm
Weight 21.7 lbs.
S5's Front size
Outer Dia. 340.0mm
Height. 51.9mm
Nom Thick 30.0mm
Min Thick 28.0mm
Hub Size 68.0mm
Bolt Size 15.2mm
Weight 23.65 lbs.
A5's Rear size
Outer Dia. 300.0mm
Height. 36.0mm
Nom Thick 12.0mm
Min Thick 10.0mm
Hub Size 68.0mm
Bolt Size 15.3mm
Weight 12.2 lbs.
S5's Rear size
Outer Dia. 330.0mm
Height. 36.1mm
Nom Thick 22.0mm
Min Thick 20.0mm
Hub Size 68.0mm
Bolt Size 15.2mm
Weight 17.1 lbs.
Yes, it can be done but you need to change the calipers and pads: also you might have to change the wheels if you aren't running 18" rims as 17" wheels will be too tight for the S5 brakes (an S5 was never designed to run 17" rims hence larger rotors whereas some A5s do run 17" wheels....)
10.000v in my arms......but the lightbulb in my head still won't light up......
A7 Sportback 3.0 TDI Quattro S Tronic
Full Metal Jackass is offline
post #3 of 17 Old 24th July 2011, 03:08 AM
labombadiesel's Avatar
That's not true, at least with the v6 engine A5s...
The v6 A5 has the same brake calipers as the S5, being the only difference between their brakes the size of the discs and the callipers holders which are bigger, so if you have a v6 A5 you would only have to buy the S5 discs and calipers holders to upgrade it...
Air121005 likes this.
labombadiesel is offline
post #4 of 17 Old 24th July 2011, 04:11 AM
Quoted: 36 Post(s)
Sorry that's not truth.
A5 3.0TDI front calipers and pads nr.:
8K0 615 123B/124B, 8K0 698 151E
S5:
8T0 615 123B/124B, 8K0 698 151D
so they are different.
Rear calipers and pads are different due to disc thickness and diameter.
2011-??: S5 4.2 FSI manual, auxilliary heater, keyless, memory seats, navi, rear cam, etc.,
upgrades: chiptuning, Vmax off, Milltek resonated exhaust, VCDS mods (ADS, TPMS, highway lights), ADS switch, RS5 pedals, Bluetooth, LED rear lights, OZ Racing Superturismo Le Mans wheels (graphite grey).
2007-2011: A5 3.0TDI Quattro Sportmotor edition, KW V2, Caractere, OZ Ultraleggera HLT 19'', chiptuning 220kW, K&N, Milltek, LED, RS5 pedals, lots of VCDS mods
post #5 of 17 Old 25th July 2011, 07:40 AM
The difference in the S5 and V6 TDi or Non-TDI is that the caliper has a black S5 sticker on it, other than that all calipers are the same on the front.
usmc1488 is offline
post #6 of 17 Old 22nd October 2011, 12:29 PM
Sorry for late reply but is it 100% true that S5 calipers are same to A5 3.0TDI's apart from color?
I consider replacing my 2.0TFSI's 320mm rotors to 345mm and it's important to understand if I may leave stock calipers intact, replacing just carriers/rotors/pads.
Tomcat-R is offline
post #7 of 17 Old 22nd October 2011, 12:33 PM
S5:
C99, would you please share the PR code of your 3.0 TDI front brakes according to ETKA?
Many thanks!
Tomcat-R is offline
post #8 of 17 Old 25th October 2011, 06:10 AM
This are the official type and sizes of A5 3.0 TDI and S5 brakes...
Front and rear...
The only difference between both is the disc size, and accordingly the caliper carrier.
The rest is exactly the same.
This is official technical Audi information for the spanish dealers...
Tha data are:
Engine
Minimum wheel size
Brake type
number of brake pistons
brake piston diammeter
brake disc diammeter
Name:	FRENOS DELANTEROS A5-S5.jpg
ID:	11944   Click image for larger version
Name:	FRENOS TRASEROS A5-S5.jpg
post #9 of 17 Old 25th October 2011, 08:20 AM
Front and rear...
Tha data are:
Engine
Minimum wheel size
Brake type
Thanks! It actually means 3.0TDI has 320 / 300 mm rotor setup, not 345 / 330 mm?
Tomcat-R is offline
post #10 of 17 Old 30th October 2011, 10:03 AM
Yes, that's right...
post #11 of 17 Old 30th October 2011, 10:36 AM
does this hold true for the 3.2 V6 as well?
Bspec is offline
post #12 of 17 Old 30th October 2011, 10:01 PM
Yep.
Tomcat-R is offline
post #13 of 17 Old 30th October 2011, 11:21 PM
Searching in ETKA and TRW Aftermarket catalog has revealed several interesting facts:
1. Audi Q5 SUV has two front brake setups - 1LA and 1LJ
- 1LA is similar to A5 - rotor, caliper carrier p/n's are same
- 1LJ is similar to S5 - rotor p/n is the same, caliper carrier p/n's are different (due to color)
2. Audi Q5 has same front caliper p/n's for both setups - 1LA and 1LJ
Applying some logic to the abovementioned facts brings to the following:
- front calipers are interchangeable between 1LA and 1LJ setups
- Q5 has same caliper carriers as S5, but in gray color
Tomcat-R is offline
post #14 of 17 Old 13th August 2012, 12:37 PM
Sorry to dig this topic up
Just wanted to see if anyone had any input.
I have a 2.0T and going to be putting on a 380 bbk on the front and wanted slightly larger rears.
As stated above the s5 rear rotor is 22mm and the a5 is 12mm. Are the s5 and the a5 caliper the same? I will be getting larger caliper carriers to accomodate the 330 vs. 300 size rotors but how would the width of the rotor affect it? (I checked hawk performance and the pads have the same part number for an a5 and s5)
ubiquitous is offline
post #15 of 17 Old 13th August 2012, 10:08 PM
dazzyd's Avatar
Hi ubiquitous,
wow that is some huge front BBK.
i think the rear S5 and A5 are different in terms of thickness of the brake rotor.
i know that you can change the rotors of S5 to the RS5 and still retain the same calipers but not for the A5 to the S5.
i upgraded my front and Rear Brakes to the RS5 types hence i had to change the whole lot, rotors and calipers.
hope this helps.
MY11 A5 Sportback 3.0TDI -19" Y Arm -B&O Sound-MMI 2013 3G Navigation-Sunroof. MODS-Non S-line BodyKit, APR STronic Remap, 2013 F/L Rear DRL, Eibach Sways, APR Carbonio CAI, MTM Cantronic Module, Supersprint Exhaust, RS5 BBK F+R, Goodrich SS Braided Hoses, Eibach 20F & 12R Adaptors, Bilstein B16 PSS10 Coils, RS5 Pedals, LED Interior-License-Park-Reverse-Indicator-Fog, 6000K xenon, RS5 MMI Panel, 2013 Seat & Window Switches, 2013 Air Leather Gear, 2013 RS5 FBSW, MAcarbon CF Paddles
dazzyd is offline
post #16 of 17 Old 30th May 2015, 05:15 PM
jschrauwen's Avatar
Digging up an old thread. BTW, some very good data in here for me since I'm a new A5 owner (2 weeks). 2008 US spec 3.2L
I like to gradually piece together a moderate front and rear BBK. Specifically, I'd like to upgrade to oem Brembo's front and rear.
I realize this may require slightly larger rotors and possibly caliper adapters/carriers but I need them to fit under oem 18" wheels.
Please correct me if I'm wrong, but I understand that perhaps the Q5 front Brembo is a direct bolt-on to the A5. It uses a 345mm front rotor. I believe all that's required is perhaps longer caliper mounting bolts?
If this is true, this is only a slight increase in rotor diameter over the oem 320mm which "should" still leave plenty of clearance for the 18" wheels.
But I'm still at a loss as to how I could accomplish something similar to the rear.
jschrauwen is offline
post #17 of 17 Old 26th June 2015, 02:40 PM
Not shilling for a vendor, but ecs tuning has a Stage 1 brake kit which is essentially the larger S5 rotor and a bracket to move the caliper out to fit ($300up depending on the rotors you select), and a Stage 2 kit that is the Q5 Brembo calipers and larger rotors ($1099up depending on rotors). The only rear kits are true full replacement and are quite pricey as they have carriers, rotors, calipers, etc. They are the only ones who have the bracket to upgrade from A5 to S5 front brakes, and the only ones who do the Q5 upgrade, that I've found. Either one really helps the braking (I have the Stage 1, which is fine as I do not track my A5, that's what the Vette is for!) and is FAR cheaper than a full Stoptech or Brembo upgrade...
Os.
P.S. Sorry for the prices in dollars, I'm not sure of the Pound or Euro conversion rates!
Osmodious is offline
