A5 sportback 2017 - Handbrake not (alway) engaging - Audi A5 Forum & Audi S5 Forum
  • 1 Post By plat27265
post #1 of 13 Old 18th May 2017, 12:50 PM Thread Starter
Dear All,
I am an entusiastic owner of a beatuful A5 sportback 2017 sline automatic. I really love it. Here my question for you:
When I turn off the car pushing the on/off button usually she goes in P and the handbrake gets engaged. Unfortunately sometime she goes in P but the handbrake stays [B]not[B] engaged.
I was trying to replicate the problem to understand if there was a pattern but no clue. Sometimes it just does engage.
Any tips?
Thanks in advace
Stefano
stegal is offline
post #2 of 13 Old 18th May 2017, 01:50 PM
julianwhitta's Avatar
Quoted: 359 Post(s)
Welcome aboard, Stefano. I suspect there's too few people here with the B9 platform car to give you a solid answer. I do know there's quite a few new bells and whistles with the new gear shifter. Your best bet is to take it to the dealer and get them to look at it.
2012 (fl) A5 Coupe 2.0 TFSI Quattro S-line, Lava Grey
julianwhitta is offline
post #3 of 13 Old 18th May 2017, 09:47 PM Thread Starter
Thanks for your answer.
I will have a word with my garage.
PS what B9?
stegal is offline
post #4 of 13 Old 19th May 2017, 12:56 AM
Hassan's Avatar
PS what B9?
Refers to your model/shape compared to ours which is the B8 (older)
Hassan is online now
post #5 of 13 Old 19th May 2017, 01:21 AM
Quoted: 30 Post(s)
Is your seatbelt on everytime you try the auto-on park brake?
I know the park brake won't disengage automatically if your seatbelt isn't on.
post #6 of 13 Old 19th May 2017, 09:35 AM
Quoted: 125 Post(s)
When you press 'P", is the door open? In my B8.5 S5, my EPB (Electronic Parking Brake) automatically engages if my door is open regardless of whether I am on "P" or not. After I wash the car and just before parking it, I make it a habit not to engage the EPB to allow the brakes to dry without the pads pressed onto the wet brake rotors. To do this (this observation is based on my B8.5 S5 not a B9) I keep the car doors closed, keep my seatblet on, shift the tranny to "P" and push the Start/STop button to turn off the engine. Doing it this way will keep the EPB from activating after the engine is turned off. I then apply wheel chocks as a safety measure so the car won't roll off my parking spot.
If you want to constantly have EPB turn ON every time you press the "P" button, try unlocking your seatbelt before shifting to "P". See if this works all the time.
plat27265 is online now
post #7 of 13 Old 19th May 2017, 09:40 AM
Quoted: 125 Post(s)
BTW, when forum members mention B8, B8.5, or B9, these codes refer to the internal Audi platform codes for the A5/S5/RS5 and A4/S4/RS4.
B8: MY 2008 to 2012 (in some regions, 2007 to 2011)
B8.5 MY 2013 to 2017 (in some regions, 2012 to 2016)
B9: MY2018 to present (in some regions, 2017 to present)
Audi A6 line uses codes that start with a "C"
Audi A8 line uses codes that start with a "D"
Hassan likes this.
post #8 of 13 Old 19th May 2017, 12:33 PM Thread Starter
hi, i never press P. My way to go is: I park the car, door closed of course, push on/off button (keeping brake pedal down). Now 4 out 5 if I do so engine goes off, car cose in P and EPG get engaged. 1 out 5 car engine gose off, car goes in P...but EPG does not engage.
Very annoying.
stegal is offline
post #9 of 13 Old 19th May 2017, 12:49 PM
fred44nl's Avatar
I have 2 questions here:
- why do you want the brakes to engage, since just P would be good enough.
- what does the manual say about this??
A5 SB 2.0 TFSI 155kW quattro Pro-Line S-tron. (16 febr. 2010 - .....)
A3 HB 2.0 FSI 110kW Pro-Line - 8P (26 jan. 2007 - 16 febr. 2010)
 MacBook Air 4.2 - i7 - 256 GB SSD (aug. 2011) - Sierra
Original Ross-Tech cable with Vag-Com/VCDS - 16.8.3
fred44nl is offline
post #10 of 13 Old 19th May 2017, 01:07 PM
Quoted: 125 Post(s)
For me, this is a habit that I have learned since I started driving during my teen years. Put the stick in 1st gear, pull the hand brake and turn off the engine. This is done just in case first gear pops out to neutral by accident. You do not want your car to just start rolling downhill in the middle of the night or when you are distracted. Also, engaging the handbrake minimizes stress on the transmission gear especially when the car is parked on an inclined road.
For auto trannys, the same reasoning applies concerning stress on the parking pawl. Without engaging the handbrake, the parking pawl or pin could bend under the stress of bearing some of the weight of the car on an inclined surface. For those who do not know,
A transmission parking pawl is a metal pawl (or pin) that engages a notched ring that is attached to the transmission's output shaft when the transmission shifter lever is placed in the "P" Park position.
Most vehicle manufacturers and auto mechanics do not recommend using the transmission's parking pawl as the sole means of securing a parked vehicle, instead recommending it should only be engaged after first applying the vehicle's parking brake. Constant use of only the parking pawl, especially when parking on a steep incline, means that driveline components, and transmission internals, are kept constantly under stress, and can cause wear and eventual failure of the parking pawl or transmission linkage. The pawl might also fail or break if the vehicle is pushed with sufficient force, if the parking brake is not firmly engaged. Replacement can be an expensive operation since it not only requires removing the transmission from the vehicle, but it's usually the first component to be installed in the gearbox case during a complete rebuild.
It is highly inadvisable to use the parking pawl to stop a vehicle in motion. Modern parking pawls are connected to a safety mechanism that prevents the pawl from engaging unless the vehicle is stopped first. The pawl mechanism is generally not strong enough to stop a vehicle in motion, if it engages at all. Under that much stress, the pawl may simply break off in the transmission, leading to costly repairs.
post #11 of 13 Old 19th May 2017, 01:14 PM Thread Starter
I think I was not clear.
I am not saying I want the breaks to engage, it does it automatically...just it doesn t do it every time. The behaviour is just not consistent!!
If for 4 time in a row the car engage the breaks when I hit On/off i am expecting so also the 5th time too and if it doesn t it annoying and potentially dangerous.
My question is is there a logic behind that I am missing???
Manual does not say anything specific on this
stegal is offline
post #12 of 13 Old 19th May 2017, 01:15 PM Thread Starter
sorry pal but this comment does not help me in my problem
stegal is offline
post #13 of 13 Old 19th May 2017, 01:55 PM
Quoted: 125 Post(s)
I wrote it in response to fred44nl's question. It was not meant to try to address your problem because it is not, as you said, helpful to you. Cheers!
