A5 Cab rear courtesy light failure - Audi A5 Forum & Audi S5 Forum
post #1 of 8 Old 19th March 2017, 07:46 AM Thread Starter
having had my last A3cab stolen and never recovered I thought I would protect my new beast , its an A5 cab, ...and i am trying to fit it with a tracker. I tried to find a permanent live in the roof rear courtesy light....I thought I had struck gold but alas ...when I tapped into the wires and put it all back together it didn't work....but the light did...
my investigations indicated there was insufficient voltage...only 6.5v once both tracker and courtesy light were attached...and the tracker needs 9 to 15 volt
so I unplugged the lot and have now done a direct wire on to the car battery for the tracker ... the trouble is my lovely led rear courtesy/map roof lights now don't work :-( all the fuses seem ok....
I don't know what to check next....any suggestions would help.
regards
Les
Last edited by Les A; 19th March 2017 at 08:48 AM. Reason: error..ooops . its a 2013 2.0 L diesel S line A 5 Cabriolet.
Les A is offline
post #2 of 8 Old 19th March 2017, 08:46 AM Thread Starter
it gets worse !!
Yikes i have now found out other electrics are affected... my front and rear parking beepers wont work and the button for a 4 window operation wont work...
Les A is offline
post #3 of 8 Old 19th March 2017, 09:34 AM Thread Starter
oh dear its getting worse...battery drain ??
my heated rear window doeskin work either,..i am now wondering if if the engine managment system is stopping ancillary systems working barbecue it can recognise there is a direct drain on the battery due to me adding the tracker direct to the battery.
Les A is offline
post #4 of 8 Old 19th March 2017, 11:02 AM Thread Starter
and the soft top roof doesn't work either!!
Les A is offline
post #5 of 8 Old 19th March 2017, 12:08 PM
danjwilson's Avatar
Quoted: 340 Post(s)
Could be a power management issue as you suspect. Do you have access to a diagnostic tool (VCDS or similar), as there will be a code stored for power management intervention. Alternatively, remove the tracker feed and take the car for a nice run to charge the battery and see if your systems wake up.
Sent from my iPhone using Tapatalk Pro
Dan.
A5 3.0TDI quattro Coupe Blk Ed+ S-Tronic - Daytona Grey - 3G+MMI Nav, B&O, DAB, AMI, 19" Gloss Black 'Y' Design, Auto Dim RVM, Elec. Folding & Auto Dim Mem Mirrors, Cruise, Black Leather/Alcantara Elec Memory Seats, Bluetooth, LED Light Pack, Xenon Plus & LED DRL's, High Beam Assist, Parking System Advanced, Adv. Key, ADS, Adaptive Dampers, Privacy Glass, Storage Pack, BlackVue
Previous - A5 3.0TDI quattro, Blk Ed, S-Tronic - Glacier
Previous - A5 3.0TDI quattro Sport Coupe - Silver
danjwilson is offline
post #6 of 8 Old 23rd March 2017, 01:09 PM
Quoted: 30 Post(s)
if its under warranty.......play dumb lol..........say nothing get it fixed or get vcds on it read fault codes,maybe just a reset will sove it,if not.....disconnect battery for around 20 minutes,reconnect see if it helps.
vw754 is offline
post #7 of 8 Old 27th March 2017, 12:22 AM Thread Starter
hi thanks for the help..
sadly i dont have a diagnostic machine.... so i had to pay £120 to get Audi to look at it....
they have said there was a water leak on the roof box seal... water was found in the bottom of the right side rear, boot fuse housing ....apparently this has corroded a fuse which caused a resistance irregularity, which they have now cleaned up and replaced....they said this probably caused a management failure, they reset all the faults to zero and hey presto everything is fine.... apart from my wallet. they have suggested i renew the roof box seal at a cost of £250 !!....
an expensive lesson was learned ... check fuses in more detail....and consider getting a diagnostic machine
once again thanks for the help... i still have to fit a tracker but next time i will be more careful...
Les A is offline
post #8 of 8 Old 27th March 2017, 01:45 AM
After this experience Les I would seriously suggest that you go to a specialist and get a tracker fitted by the pros. The power lead is vital as otherwise if the thieves just remove one wire from the battery the tracker is dead then its not really much use. I have a Cobra system fitted to my A5 and to my Vito van and I know it works cos they called me when some t**t broke a van window in a bungled theft attempt, and they called me when I was on the ferry over the channel just to check that I knew my van was on the water.........and the annual subscrition these days is fairly minimal.
162,000km. Full black leather interior. Love it !!
Recently had the wheels refurbished, bodywork polished, badges removed and fitted the pedal box booster. Full set of new Brembo discs and pads just fitted and calipers repainted in silver. New carbon mirror covers.
