MMI 3G navigation 6.22.4 and firmware updates - currently 2016 - Page 13 - Audi A5 Forum & Audi S5 Forum
 43Likes
post #361 of 443 Old 14th December 2016, 03:42 AM
Unhappy
So after re-reading other peoples steps i have managed to install the new maps! all done except activating it. - took exactly 2.5 hours as mentioned
i have a few questions and i would be greatful if anyone can clear this up for me.
from maps 5.10 to 6.22 - is there a visual change or do maps appear the same?
do you get full postcode search when up to date?
can any of you guys try searching for this post code: SE7 8AU and let me know if you can even navigate the SE7 area? - i cant get this to load and i live around that area so need it from time to time.
should i notice any other difference from firmware 0022 to 257 and the same for maps 5.10 to 6.22?
any help would be great!
thanks
J
Jamie Sands is online now
post #362 of 443 Old 14th December 2016, 04:17 AM
fred44nl's Avatar
the firmware update is for bugs, not for improvements or additions.
the new maps looks the same as the old ones; the only difference would be newly changed and/or added roads.
don't think you will have changed or different behavior, when it comes to postal codes.
A5 SB 2.0 TFSI 155kW quattro Pro-Line S-tron. (16 febr. 2010 - .....)
A3 HB 2.0 FSI 110kW Pro-Line - 8P (26 jan. 2007 - 16 febr. 2010)
 MacBook Air 4.2 - i7 - 256 GB SSD (aug. 2011) - Sierra
Original Ross-Tech cable with Vag-Com/VCDS - 16.8.3
fred44nl is online now
post #363 of 443 Old 15th December 2016, 03:48 AM
Smile
great thanks! my only issue now is i cant use the GPS for my local areas SE7 and SE18 of london, is this a common bug or an issue for my vehicle?
i cant add pictures, but it basically is all grey out apart from special locations.
does any one know if this is fixable?
it pulls up the road names and such when just looking at the maps, so i know its there, but this issue has been the same for the old maps and new maps!
any light any one can shed?
Jamie
post #364 of 443 Old 16th December 2016, 01:50 PM
I have a 2011 audi with a very old software version but I cant seem to find an update. The dealer is giving me the run around. Can any one help, I live in North America.
Nav Database Version is 8R0060884P NAR 5.4.7
HNav_US_PO114_D1
Is there a newer version that I can download somewhere, do I need some special activation from the dealer? Please help.
brey49090 is offline
post #365 of 443 Old 16th December 2016, 01:53 PM
Unhappy 2011 audi q5
Software update help, I have a very old Nav version and live in North America but the dealers are giving me the run around. Do I have to Pay 400.00 to upgrade this system or is there a download somewhere? please help.
Hnav_US_PO114_D1
post #366 of 443 Old 17th December 2016, 12:46 PM
Hey,
just a quick one for people who have an older nav - there is something a bit different from the older maps, they now give the split screen section showing which lane to be in - which i never had on my older gen.
also can any search the SE7 post codes and let me know if theirs works? its rather annoying i can get my own local area on my nav
i hope its a bug with mine and not for every MMI 3G!
post #367 of 443 Old 17th December 2016, 12:52 PM
fred44nl's Avatar
this has always been the default, when approaching a junction on motorways.
well, it was on mine
this split screen is one of the main differences between B-nav and H-nav.
post #368 of 443 Old 19th December 2016, 10:51 AM
Hey guys.
Got my A6 with 3G high update to _6 firmware as well as got the maps successfully updated.
However, I am not at the point where I need to activate the maps as I'm getting the Navigation blocked message.
My question is where do I find this activator?
EDIT
Nvm folks. Found it. Everything's up and running.
Thanks for the great guide!
b0gd4n is offline
post #369 of 443 Old 21st December 2016, 03:15 AM
2009 a6 3g
Hey!
I went from firmware version P0022_D1 straight to K0257_5_D1 by a copy/paste mistake. Do I have to start from the first update again before updating maps or just leave the K0257_5_D1 installed as everything is working?
edit: scrolled through the pages again and found the answer on page 11. You can go straight from 22 to 57
Unisol is offline
post #370 of 443 Old 29th December 2016, 11:11 AM
Hi
I have a 13 Reg A5 sport back with this firmware, im in Ireland
Media Version
HN+_EU_AU3G_P0612
Nav Database ~Version
8R0060884AR ECE 6.15.5
How do I go about to update the maps / firmware
tech is offline
post #371 of 443 Old 1st January 2017, 03:24 PM
congo's Avatar
Quoted: 142 Post(s)
Check the thread for MMI 3GP, it's all in there for your car.
Sent from my iPad using Tapatalk
Recovery of "bricked" MMI 3G units - 3G Basic (DVD-Rom;7T2), MMI 3G/3G+ (HD;7T6), RNS850, MIB1 and MIB2 IPL restore US to EU conversion
MMI 3GP K0900 MAP 2016, MMI 3G HIGH K0257 MAP 2016, MMI 3G BASIC K0260 MAP 2016, MMI 2G HIGH 5570 MAP 2016
RNS850 K0821 MAP 2016/2017 7P6060884E 6.23.2 Europe V10 Google Earth/Sreet View on RNS850
5.8.6 2016 RoW MAP 8R0051884DJ
Coding of STG 46 Halogen to LED tail lights A4/8K A5/8T A6/C7 A7/4G || Turning off start-stop system
congo is online now
post #372 of 443 Old 5th January 2017, 05:33 AM
Vcds
Hello,
I am quite concerned doing this encase it goes wrong...however, the pre-requisites state having access VCDS. How do I go about doing this? Is it a cable I require to connect to my laptop running software?
Where do I get the cable?
Where do I plug the cable?
Where do I get the software?
Thanks,
Dean
drallop2000 is offline
post #373 of 443 Old 7th January 2017, 02:03 PM
I have a problem after update. I've updated from 022 to 257 newest from package. Then I've cleared nav partition, install recent nav database. After that I've activated maps. Deleted error with wrong dataset and svm as it is written in pdf.
Right now everything is working properly, but I cannot get GPS fix. In green menu active satellites equals 0 and hdop parameters are 999. So navigation stores last known position before I went to garage and did update. Any suggestions?
olinek2 is offline
post #374 of 443 Old 7th January 2017, 03:06 PM
Quoted: 14 Post(s)
Have you driven anywhere since you did it? I think you need to move at least 100m before it starts working.
Quasimotor is offline
post #375 of 443 Old 8th January 2017, 01:21 AM
Yes I have. I've moved many times. Even I've tried to delete calibration in green menu but still I don't have any signal. I don't think that new antenna which was working properly after update has died.
I will probably swap main unit in friends car to check it. If it doesn't help I will clear database again and nav partition and install maps again. Maybe you have different suggestions?
olinek2 is offline
post #376 of 443 Old 9th January 2017, 01:54 AM
Thumbs up mise à jour MMI et carte
Bonjour à tous,
Tous d'abord merci pour tous ces précieux renseignements !!!
Je tenais à dire aux éventuels Français du Forum que le tutoriel fourni ici pour les mises à jour est tout à fait fonctionnel et opérationnel !!!
Le firmware de mon A4 Avant Sline de 2013 est maintenant en version 900 et ma cartographie en version 2016...
Plus qu'à m'attaquer à l'audi connect sans emplacement SIM (matériel acheté...) pour obtenir google Earth et la boucle sera bouclée..
Merci encore !
stephge is offline
post #377 of 443 Old 9th January 2017, 07:56 AM
It came, that GPS antena had died. I've exchanged my unit in friends car and it has signal.
olinek2 is offline
post #378 of 443 Old 11th January 2017, 10:17 AM
Hi guys,
I have one quick question: Can I update my firmware to 0257_6.rar directly? or I need 0257_5 too?
P.S: Sorry for dumb question :/
Best Regards.
Alex88 is offline
post #379 of 443 Old 11th January 2017, 10:21 AM
fred44nl's Avatar
you are in the wrong topic.
pls go here:
MMI 3G Basic navigation 5.22.3 and firmware updates - currently 2016
post #380 of 443 Old 11th January 2017, 10:32 AM
Hi fred44nl,
Damn! I knew it that I was lost
Thank you.
Best Regards.
Alex88 is offline
post #381 of 443 Old 12th January 2017, 07:55 AM
Eventually got round to updating the sat nav.
As the usual, it took 2.5 hours to fully update. Started the update and went and watched the new Jason Bourne film
I didn't have access to the green menu, so I took a risk and updated it for the first time in it's life span, still had a map version from when it was bought new 6 years ago.
Sitting on firmware _6 it installed, rebooted, activated as it should and by the time I let the system fully boot up it had found 10 sats and has the latest maps.
Cheers for the help in this thread guys..
Roblin is offline
post #382 of 443 Old 15th January 2017, 02:18 PM
Hi guys, I readed all thread but I am not sure if I found answer for what I am looking for.
I downloaded all files but the 3rd part of firmware looks not same like the other (its OK?)
My version is:
Software version:
Hnav_EU_K0206_3_D1
Nav. database version:
8R0060884N ECE 5.12.5
So I think I need just 3rd - 5th part of firmware update. But can I just update the last one without 3rd and 4th?
Thank you all for your answer
P.S.: Sorry about my english
Mino
Mino is offline
post #383 of 443 Old 19th January 2017, 12:40 PM
Will those maps work for following version?
HN+R_EU_AU_P0783
8R0060884BT ECE 6.19.3?
Thanks for feedback!
dipsyke is offline
post #384 of 443 Old 19th January 2017, 02:17 PM
fred44nl's Avatar
HN+R_EU_AU_P0783
no, you are in the wrong topic !!
this is where you go:
MMI 3G+/3GP navigation...
post #385 of 443 Old 24th January 2017, 11:23 PM
Hello
Hi have updates some years a go bit didnt manage to run it whit navi via DVD, i think software did update.i have current this version running whit old original DVD from Audi.
What steps do i have to male?
Enviado de meu Redmi Note 3 usando Tapatalk
hrdgomes is offline
post #386 of 443 Old 25th January 2017, 01:11 AM
fred44nl's Avatar
please go here:
post #387 of 443 Old 26th January 2017, 08:59 AM
Quoted: 11 Post(s)
Hello friends, I see that CONGO to uploaded maps 2017 for mmi 3gp, my question is:
I have mm 3g hdd and do all the work put in this post, it turns out I need activator for new maps or else I have to enter "ECE_" and put everything in Y?
tecshuo is offline
post #388 of 443 Old 29th January 2017, 04:50 AM
Please can someone advise if an update to the version I am running is expected to be available anytime soon?
(I think I am in the correct thread, but looking through these are getting messy over the years so apologies if not)
HNav_EU_K0257_6_D2
8R0060884DF ECE 6.22.4
Thanks all
2010 A5 Sportback S.Line, 2.0 TSFI, 211bhp, Brilliant Red, 3G Adv. HDD Nav, B&O, AMI, DVD, Elec Lthr/Alcantara seats, DAB - Northamptonshire UK.
fenny123 is offline
post #389 of 443 Old 1st February 2017, 01:37 AM
Question New owner with OLD firmware & maps
Hi guys, I have recently bough and Audi Q5 09 Reg with MMI 3G HDD and I've checked the firmware and maps and obviously are OLD, I think previous owner didn't update.
Software Version: HNav_EU_P0022_D1
Nav. Database Version: 8R0060884E_ECE 5.8.5
I've been reading a lots post on this forum and I think I know how to do it but still I would appreciate if someone can answer the following questions if you don't mind.
In regards to update the firmware, due to I can read is a pre-requisite to update the maps to latest version, I should first update the firmware using the following firmware versions:
  • 1 st – 8R0906961T – firmware 0031
  • 2 nd – 8R0906961AS – firmware 0206
  • 3 rd – 8R0906961CC – firmware 0253
  • 4 th – 8R0906961DF – firmware 0257
My questions about firmware update:
  1. It's possible copy all firmware software, one folder per firmware, in the SD Card and then start to apply the firmware update selecting specific folder/version and NO update maps? .. I mean, basically I've read update take a lot time, and then I would like to split the work, first update the firmware, and maybe other day update the maps? How long take update the firmware (per version)?
  2. I'm worried about if something goes wrong with the firmware update, under your experience, should I have anything very important in consideration (I know I should remove any other media from mmi and also disconnect bluetooth)
  3. The update should be done with engine started or should be enough with ignition on?
In regards to update the maps:
  1. Should I delete the maps partition using the green menu? or your recommendation is try to update with existing partition and if it doesn't work then delete the partition
  2. Still I didn't enable the hidden green menu, Do you recommend? .. I got yesterday an OBDII wifi device and I think I can do it with ARISTA app, not sure if pay just one week or otherwise pay one year subscription
By the way, I have just Mac (OSX) computers, but I understand if I uncompress the rar folders with Arhiver app should be work, also I think I should delete any file like DS_Content from SD Card etc.. As alternative I can install a Windows using VMWare, Which one is your recommendation?
Thanks for everything, and sorry if any of these questions are already answered but to be honest I couldn't find it .. too much threads/questions.
Best regards
rcerro is offline
post #390 of 443 Old 1st February 2017, 02:08 AM
fred44nl's Avatar
@rcerro
firmware-update:
1.
you cannot put all the firmware-updates on the SD-card, all together.
this has to be done one at a time.
make sure the files are at the root of the SD-card and not in a folder.
2.
my A5 is from early 2010 and needed also the 4 four mentioned updates.
it did work without any problem, as long as you follow the instructions in the pdf.
3.
the updates must never be interrupted, in any way.
I always had the engine going, in order to prevent a flat battery.
maps-update:
1.
I have never deleted the partition, as mentioned in the instructions.
afaik you can always do that, in case the maps don't fit.
my A5 has been updated 3 of 4 times now, always on the same partition.
2.
you don't need the green hidden menu, as far as updating is going.
being on MacOS you will have to take care of the special hidden files, that are always placed on usb-sticks and SD-cards.
I have an app for that, called: Eject for Windows
