Help with a few VCDS error codes. - Audi A5 Forum & Audi S5 Forum
post #1 of 3 Old 5th January 2016, 03:18 AM Thread Starter
Hey guys!
I need some help "deciphering" these VCDS error codes:
Code:
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 T    HW: 4E0 035 729
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 329D/077508968
   Coding: 0005001
   Shop #: WSC 00000 000 08192
   VCID: 4A97E12B75BF09539D7-801E
   Subsystem 1 - Part No: 8T0 919 609 C
   Component: E0380 BedienteilH07 0100
   Subsystem 2 - Serial number: 00000000003518
   Subsystem 3 - Serial number: 0114.04.070000000100010047я
   Subsystem 4 - Serial number: 010047я
1 Fault Found:
00003 - Control Module
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 194499 km
                    Time Indication: 0
                    Date: 2015.12.07
                    Time: 00:54:18
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
   Component: GW-BEM 4CAN-M H07 0083
   Revision: --------    Serial number: 3100E07329807F
   Coding: 000003
   Shop #: WSC 31526 143 87166
   VCID: 448BCF13579BDF2367B-8010
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
3 Faults Found:
01303 - Telephone Transceiver (R36)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 194499 km
                    Time Indication: 0
                    Date: 2015.12.07
                    Time: 00:55:19
03041 - Energy Management Active
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 7
                    Fault Frequency: 3
                    Reset counter: 195
                    Mileage: 194577 km
                    Time Indication: 0
                    Date: 2015.12.14
                    Time: 01:11:00
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 7
                    Fault Frequency: 2
                    Reset counter: 195
                    Mileage: 194577 km
                    Time Indication: 0
                    Date: 2015.12.14
                    Time: 04:22:00
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760     HW: 8T0 959 760
   Component: MEM-FS        H08 0026
   Revision: AA000000    Serial number: 00001001002321
   Coding: 08017025002444441000
   Shop #: WSC 00920 264 175062
   VCID: 55AD0257AC0156AB005-8000
1 Fault Found:
03338 - Force Limit for Fore/Aft Seat Adjustment: Forwards
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 194499 km
                    Time Indication: 0
                    Date: 2015.12.07
                    Time: 00:54:00
I am absolutely clueless in regards to the first and last ones. I'm guessing that the second one is related to my non-functioning phone (I'm not sure which one in particular I got, a VIN check revealed this - 9ZF = Mobile phone preparation with hands-freespeaking system / QF0 = Without receiver (car phone)). The errors that follow (from what I read) could be related to a car battery that needs to be replaced, although the MMI battery check is showing 100%. Any help will be greatly appreciated Thanks!
Loyal2DaGame is offline
post #2 of 3 Old 6th January 2016, 07:46 AM
Quoted: 60 Post(s)
For the last error: it's because of your battery indeed. Solution: Run the the seat all the way forward and all the way back using the controls on the side. Keep holding the control in the forward or backward position for a second or two after the seat reaches its limit of travel.
Contact me for rear light LED adapters and other wire harnasses for retrofitting. (RS5 rear spoiler, heated seats, PDC etc etc)
Baas J. is offline
post #3 of 3 Old 6th January 2016, 08:11 AM Thread Starter
Thanks, mate, I'll do that and report back. As far as the battery is concerned, I guess I'll have a look at the more in-depth VCDS battery diagnostic readings.
